Source for Warning Label and Signs?
bart
Solar Expert Posts: 30 ✭
I'm not having much luck finding a source for ready made PV warning signs and labels. I was hoping someone here could direct me?
Need:
"CAUTION: SOLAR ELECTRIC SYSTEM CONNECTED"
"CAUTION: SOLAR CIRCUIT"
AND Warning signs per article 690.53 NEC 2008?
Thanks, Bart
Need:
Thanks, Bart
Re: Source for Warning Label and Signs?
A thread here:
NEC Permanent Label Requirements
And:Drew up a caution plaque last night using OpenOffice Impress, emailed a copy to the SDG&E NEM guy to see if he liked it before I turned it into a sign. He liked it (very quick reply!) and I called up a local trophy/sign shop. Emailed them a copy of the sign in bmp format and they should have it done in the next day or so and will cost me about $15. Good deal!
I dont know if this will be much help to you, but I am a printer by trade, and can have these plaques made for you. You just need to give me the size you need, and I can give you a price, and have them shipped out to you.
They would be plastic, Red background White letters Engraved, with holes or sticky-back (Holes are better for outside) -
Thanks for the info...
Bart -
Bart, have you tried a trophy shop, they might not have the paper stickers, but can use the hard plastic "stick-on/screw-on" labels? -
No affiliation, but I had mine made here:
www.A2Zthrophy.com
Engraved plastic with adhesive on back
1 x 3 were $4 each and 1-1/2 x 3 were $8 each -
Like the others, I found a local trophy shop able to supply the required plastic signage at a reasonable price - just provided them a diagram of what I needed and they turned it around in a day or two. -
http://www.mysafetysign.com/
thats where I got mine from...you can make custom signs on the website
just look at my pic12 panels 6 series 2 parallel 2100 watts, 1 XW60-150 CC, 16 trojan 6V batteries 8 series 2 parallel 450 Ah, 1 XW 6848 pro, 1 5500 watt champion inverter generator( I know...I need a 12Kw ) -
I saw a Harley once with this one on the gas tank:
http://www.mysafetysign.com/Safety-Signs/Hazard-Play-On-Around-Sign/SAF-SKU-S-2649.aspx
I like this one a lot
http://www.mysafetysign.com/Safety-Labels/Computer-Controlled-Interfere/SKU-L-0275-XV.aspx -
I need a t-shirt with the second one......sometimes I think my computer does control me12 panels 6 series 2 parallel 2100 watts, 1 XW60-150 CC, 16 trojan 6V batteries 8 series 2 parallel 450 Ah, 1 XW 6848 pro, 1 5500 watt champion inverter generator( I know...I need a 12Kw ) -
i had to sign up to leave this comment. When my usual source for labels were sold out, i did a google search and found only a few retailers that sold them online and nothing locally. i got some at duncansolar.com and they had them all in stock and shipped same day. I thought about having them made for me too but until then, i will just buy them. They are made by Tyco, if that helps with people searching for them. -
pvlabels.com has a wide assortment of warning labels. We're installers too and have had a heck of a time getting labels that worked for us, so we did something about it. Hope this helps.
this link has been approved for posting. i can't vouch for the business. niel -
kyle@panelcraftinc.comWe keep well stocked with UV Rated Standard Colors 1/16" & 1/8" Thick
- Most orders are ready for pickup or shipment same to next day here
Sample Prices Below: Discounting on all quantities starting at 250.00 - Small or Large - Up to 50% at 5,000.00
- 1.00" x 2.00" @ $1.36
- 1.00" x 3.00" @ $1.65
- 2.00" x 4.00" @ $3.27
kyle@panelcraftinc.comAttachment not found.Attachment not found. -
labelengraving.com,
do not push your products any more. you have been allowed to let others be aware you are around with 2 such posts and this is an exception to the norm here. any more posts will need to be forum related and not aimed at selling your labels. we will allow your email address in your signature line, but do not abuse the exception you have been given.
also note this is not an endorsement for this company or products it has.
also note that any bad feedback on your company or products will result in all references to the company being eliminated.
- 621 Discussion Forums/Café
