Yukita connector compatability
NZRR
Registered Users Posts: 28 ✭✭
I am preparing to complete an installation using LG 250W modules that have Yukita connectors. In looking at the available Yukita connectors, none of these seem to be compatible with anything else (like MC4 cables). Does anyone have any experience with these modules or connectors?
Re: Yukita connector compatability
Sorry, first I've heard of them.Powerfab top of pole PV mount | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
if the connector is not of your liking then maybe email the company and ask them straight up if cutting those connectors off for either a bare wire to be hardwired or a different connector if that would void the warranty on the pvs. -
I have "heard" that these connectors are compatible with the MC4 connectors. I will let you know if that turns out to be true. Thanks. -
Multi Contact states that their connectors are not compatible with any other connector on the market. We recommend using the connectors found on the back of the panels. If you are looking for any type of connectors please visit www.titanwnc.com or call 1-888-356-1662 Hope this helps. -
If it does not say "MC4" on the connector type, then probably not compatible.
