MidNite PV Prewired Combiner MNPV4
TheBackRoads
Solar Expert Posts: 274 ✭✭
I recently purchased one of MidNite's pre-wired combiner boxes. I must say, pretty awesome and painless if your using MC4 connectors. I'm sure I paid a decent amount for it vs making my own but simplicity/ease of use got me this time.
Take a look at what our host and MidNite have to offer!
I only have 2 strings so I used an open string to connect an existing MC4 cable (furthest right) to my inside connection. For me it was click click click done.... Painless and perfect.
Thanks MidNite and NAWS!
TBR8)
TBR8)
Re: MidNite PV Prewired Combiner MNPV4TheBackRoads wrote: »I recently purchased one of MidNite's pre-wired combiner boxes. I must say, pretty awesome and painless if your using MC4 connectors. I'm sure I paid a decent amount for it vs making my own but simplicity/ease of use got me this time.
I really like the MC4 connectors. The combiner box you bought is rated to 600 volts and uses fuses.
My cold weather Voc is less than 100, and I have circuit breakers (150 v) in my Midnite combiner box.
That shows IMO that Midnite knows where the market is, the market is High voltage grid-tied.
I wish Midnite would make a prewired MC4 combiner for us 'less than 150 Voc' folks. If I needed to rebuild my system today, it would be a tough call which way to go. I like the built-in MC4 connectors, but I would rather have breakers.
Re: MidNite PV Prewired Combiner MNPV4like the built-in MC4 connectors, but I would rather have breakers.
Isn't this just an MNPV6 with MC4 connectors stuck on the bottom? That's a DIN rail in there so it wouldn't be any problem to swap in some 150V breakers. I think most off grid folks would rather build there own one of those, where as a grid tie installer with a couple $15/hr employees might rather let Midnite wire it up. -
Re: MidNite PV Prewired Combiner MNPV4I really like the MC4 connectors. The combiner box you bought is rated to 600 volts and uses fuses.
it isn't that the market is in high voltage, but that it is so easy to encompass the high and low voltage requirements in a single package as to not limit themselves to only the low voltage market. a high voltage combiner will work with lower voltages, but a low voltage combiner will not work with high voltages. costs for both would not be a factor as either would cost close to the same amount of $. -
Would you like a picture with a fuse removed? -
Re: MidNite PV Prewired Combiner MNPV4Volvo Farmer wrote: »Isn't this just an MNPV6 with MC4 connectors stuck on the bottom? That's a DIN rail in there so it wouldn't be any problem to swap in some 150V breakers. I think most off grid folks would rather build there own one of those, where as a grid tie installer with a couple $15/hr employees might rather let Midnite wire it up.
We would absolutely build them with 150 volt or even 300 volt breakers as needed. Please ask your sales person to get ahold of me for low voltage prewired combiners we will take rite care of them..
Ryan
