where to buy parts for outdoor misting systems?
rollandelliott
Solar Expert Posts: 834 ✭✭
Does anyone know where to get parts like mister heads and such for cheap? When I google misting systems all I can find are these expensive kits. Want to set one up for my out door patio.
Has anyone used a booster pump to get really high pressure and finer mist? Is the extra cost of $200 to $300 worth it? Hoping to prevent too much of a wet mess around my patio.
thanks!
thanks!
Re: where to buy parts for outdoor misting systems?
I have a misting system that is 13 years old, jets replaced about every other year, it has a 1000 psi pump. I have a local source for parts. When the humidity is higher it is a wet mess, otherwise it lowers the patio temps upto 15F. -
any chance you can post manufacture part numbers, pump model #, etc so I can google where to get the parts locally or online?
do you think this home depot one is good. Kind of expensive at $700? Maybe I'm just cheap!
http://www.homedepot.com/buy/building-materials/heating-venting-cooling/aero-mist/misting-pump-1000-psi-69583.html
edited to add home depot sells a lot of misting stuff
http://www.homedepot.com/Building-Materials-Heating-Venting-Cooling-Misting-Systems/h_d1/N-5yc1vZara8/h_d2/Navigation?catalogId=10053&langId=-1&storeId=10051#/?c=1&rpp=96
Maybe I'll just go there unless some place has better pricing.
Thanks for the reply. -
Re: where to buy parts for outdoor misting systems?rollandelliott wrote: »any chance you can post manufacture part numbers, pump model #, etc so I can google where to get the parts locally or online?
Actually that is a good price for a pump like that. Much better than what I paid. Mine is out of manufacture now. My system is all done in copper and sweated together, that could be why it lasted so long.
I have been buying locally from these guys http://www.aeromist.com/
While the prices are not cheap the quality is good and parts are always in stock. -
thanks
With Arizona's low humdity i bet it works great.
I'm in the South East. I wonder if it is even worth it since our humidity is 50% or more during all the warm months.
Average High Temperature 89 °F Average Morning Relative Humidity 86%
Average Low Temperature 69 °F Average Afternoon Relative Humidity 54%
IN phoenix the highest humdity at night is in the low 60's and afternoon around 30%.
do you use any type of screening to keep wind from blowing away all the mist? -
Re: where to buy parts for outdoor misting systems?rollandelliott wrote: »thanks
They might be questionable in FLA. It is even not as effective in late July and August when the moonsoon blows in.
No screening. -
How much misting do you need? I ran almost 40 nozzles with normal water pressure from a garden hose. I just used 1/2" PVC and drilled a hole every foot or so for the nozzles. I got the nozzles in bulk packs on Amazon. They are designed for some particular system, but I just drilled using a bit that was a tad bit smaller than the nozzle base.
- 232 Forum & Website
