Final plans for 24v system.. ready to order..
Re: Final plans for 24v system.. ready to order..
Got the 60 amp breaker wired in & mounted to the outside of the combiner box..
the Morningstar TS-45 (PWM) is due Monday and so is the 250 amp ANL fuse/block.. -
Update.. got the MorningStar TS-45 (PWM) controller..
Heres an overall shot.. (the CLAY is the Bluesea Battery Switch on order..)
[video=youtube_share;uYk1hDgaLf0]http://youtu.be/uYk1hDgaLf0[/video]
Update #2... the BlueSea Battery Swich has come in.. $21 on EB.. and I went to autozone and grabbed some marine terminal adaptors $4 just in case I ever need to use a regular 12v car battery in a bind (has the wingnuts).. I also went to HDepot and grabbed another pack of the mechanical lugs to the end of the wires at the battery end and some 6AWG 3/8" ring terminals for the wire that comes down from the charge controller.. the 60 AMP breaker for the controller to battery should be in by Saturday.. I won't post any more pics till I get the 2000w inverter..
I hope this helps others who may think diving in is the best route.. (it is not and take your time to figure before you start buying ANYTHING..) -
looks like a fun install! -
Re: Final plans for 24v system.. ready to order..Found some 3/0 - 4 AWG mechanical lugs at Home Depot.. $4.49 for 2..
BlackBurn / Thomas & Betts BTC3104-B2.. HD SKU# 526747.
Bought 3 packs so I can do my inverter leads, fuse, and battery switch..
Note.. the wire was actually 3/00 (measured the bare wire diameter).. still FREE is good..
Heres one lug installed.. :cool:
i like those lugs, how big are the holes for the mounts, 3/8"? i looked at the spec sheet on homedepot.com and it doesn't listit... -
Re: Final plans for 24v system.. ready to order..i like those lugs, how big are the holes for the mounts, 3/8"? i looked at the spec sheet on homedepot.com and it doesn't listit...
Yup.. 3/8" works good for most battery and inverters..
New video showing switch and the breaker for the controller to the battery..
[video=youtube_share;ET_6vCwCUsc]http://youtu.be/ET_6vCwCUsc[/video]
- 654 Solar Water Pumping
