Energy useage of a water pump
techntrek
Solar Expert Posts: 1,372 ✭✭✭
I know there is a water pumping section but my question is about energy useage. Just had to replace my well pump (
) and the ratings dictated that I move from the 3/4 HP pump that was installed, to a 1 HP pump. The reason is the pump depth @ 340 feet. Anyway, the change meant an increase of about 25% in amps, but the gallons-per-minute doubled so theoretically it will recharge the system in half the time. So this should mean an overall reduction in the energy used, right?
Re: Energy useage of a water pump
It could, sort of - - maybe. The heavier draw on the batteries may sufficiently involve the peukert effect, that the available energy from your batteries may be reduced, thus countering any otherwise saved energy. -
Depends on motor efficency, it's power factor, where you are on the pump curve for it, and how heavy the load is, I can see you running 2,000 w consumed, my 1/2 hp nameplate motor, shows as 1,000w on the XW6048 control panel.Powerfab top of pole PV mount | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
Thanks, all. I wish I had some "before" figures from the old pump so I could do a comparison, but no big deal. I'll wait to see how my household useage pans out over time to get a rough estimate.4.5 kw APC UPS powered by a Prius, 12 kw Generac, Honda EU3000is
- 621 Discussion Forums/Café
