PWM Inverter
Re: PMW Inverter
Most definitely not. This is an older UPS. I get stacks of UPS units with failed batteries. Some people want me to fix them, most don't. Consequently, I have a lot of UPS units.
My point being, can't go by name brand alone.
I did a quick search on Google for "Tripp Lite PWM Inverter waveform"
Found this website: http://www.repeater-builder.com/backup-power/ups-test.html
This guy is testing a Tripp Lite Omni1000LCD UPS. Yea, UPS, not a stand-alone inverter, but take a look at the specs...
Specs say: "PWM sine wave 115V +/-5%, Inverter output regulated to 60Hz +/-0.5Hz"
Here's what the waveform looks like:
Looks like a MSW to me. -
Re: PMW Inverter
We may have discovered the real reason why companies are not quick to show the output waveform of their inverters. :roll: -
Re: PMW Inverter
john p,
could you get a snapshot of the waveform on the tripplite you have?
