Solar Noon
Sun Dog
Solar Expert Posts: 115 ✭✭
I'm finally adding PV to our off-grid system and as a starting point want to get them pointing due south. My plan is to use the shadows created at solar noon to do this and I wanted to run my plan by the forum to make sure I'm doing it correctly.
Today our sunrise/sunset was 4:50am and 10:18pm. Day light savings time is over so I believe that means our solar noon is at 1:34pm, is that correct?
Re: Solar Noon
you are correct as it is the exact middle between the 2 times. -
Re: Solar Noon
OMG! How do you survive in that cold up there!? -
Re: Solar Noon
he's probably wondering how you can stand the heat down there.:p -
Re: Solar Noon
Thanks Niel. I wouldn't say that I like -40 but you do get used to dealing with it. The long days of spring and summer are a real plus. -
Re: Solar Noon
I was trying to do the same calculation when I set up my array. Then I read an idea that a quick and easy way to find a true north-south line is to go out after dark and shove a couple sticks in the ground that are in line with the North Star. -
Re: Solar Noon
Thanks for the suggestion. If we have some clear nights I will give it a try although we are fast approaching the time of year that it doesn't get dark enough to see any stars. -
Re: Solar Noon
Celsius or Farenheit? (Canada, so C, but down that low the scale is the same, and the feeling is gone from your extremities anyway!)
Ralph -
Re: Solar Noon
Crotalus,
That and many days like it.........unfortunately -
Re: Solar Noon
Cheer up, at that temperature your panels are probably so efficient they are powered by starlight and moonlight -
Re: Solar NoonCheer up, at that temperature your panels are probably so efficient they are powered by starlight and moonlight
speaking of moonlight, i measured .126v out of our recent super moon. useless, i know, but just an fyi.:roll: -
That sounds like a great research project. Just make sure you bring two pairs of shorts, layers are the key to staying warm
- 651 Solar Water Pumping
- 611 Discussion Forums/Café
