LEDs offer a brighter future, says report
Re: LEDs offer a brighter future, says report
My post on fitting G4 arrays on vehicles, has pics.
http://www.dieselplace.com/forum/showthread.php?t=448961Solar hybrid gasoline generator, 7kw gas, 180 watts of solar, Morningstar 15 amp MPPT, group 31 AGM, 900 watt kisae inverter.
Testing power consumption on LED bulb replacements vs. standard automotive bulbs and "G4 LED replacement array" testing.
http://ecomodder.com/forum/showthread.php/led-lowbeam-experiment-20498-2.htmlSolar hybrid gasoline generator, 7kw gas, 180 watts of solar, Morningstar 15 amp MPPT, group 31 AGM, 900 watt kisae inverter.
New use for LED lights bother Canadian police. Grow-op owners are now using LED lighting instead of the older high intensity units they traditionally use, thus reducing their power consumption and lowering the heat given off by the house. But in the first such operation uncovered, police say the owner was still using 5 times as much power as the neighbors.
AND THIS JUST IN FROM BBC NEWS: http://www.bbc.com/future/story/20120314-the-end-of-the-lightbulb/1 -
Re: LEDs offer a brighter future, says reporthttp://www.dieselplace.com/forum/showthread.php?t=448961
Vehicles and LEDs got together like bread and butter. -
Re: LEDs offer a brighter future, says reportI find the rapid turn-on of LED brake and turn signal lights to be a bit jarring.
Soon get used to it, a lot of folks hated the high mounted brake lights when they first came out too, but the LED's do get your attention. I find myself using that instant on instant off characteristic as a tool to spot LED equipped vehicles -
Re: LEDs offer a brighter future, says reportYes they did, but I find the rapid turn-on of LED brake and turn signal lights to be a bit jarring.
I only notice it on vehicles when the 3rd light and the main brake lights use the opposite technology (one LED, the other incandescent).4.5 kw APC UPS powered by a Prius, 12 kw Generac, Honda EU3000is
- 231 Forum & Website
