LEDs offer a brighter future, says report
2»
  • oil pan 4
    Re: LEDs offer a brighter future, says report
    My post on fitting G4 arrays on vehicles, has pics.
    http://www.dieselplace.com/forum/showthread.php?t=448961
  • oil pan 4
    Testing power consumption on LED bulb replacements vs. standard automotive bulbs and "G4 LED replacement array" testing.
    http://ecomodder.com/forum/showthread.php/led-lowbeam-experiment-20498-2.html
  • waynefromnscanada
    New use for LED lights bother Canadian police. Grow-op owners are now using LED lighting instead of the older high intensity units they traditionally use, thus reducing their power consumption and lowering the heat given off by the house. But in the first such operation uncovered, police say the owner was still using 5 times as much power as the neighbors. :D
    AND THIS JUST IN FROM BBC NEWS: http://www.bbc.com/future/story/20120314-the-end-of-the-lightbulb/1
  • ggunn
    oil pan 4 wrote: »
    Vehicles and LEDs got together like bread and butter.
    Yes they did, but I find the rapid turn-on of LED brake and turn signal lights to be a bit jarring.
  • waynefromnscanada
    ggunn wrote: »
    Soon get used to it, a lot of folks hated the high mounted brake lights when they first came out too, but the LED's do get your attention. I find myself using that instant on instant off characteristic as a tool to spot LED equipped vehicles :)
  • techntrek
    ggunn wrote: »
    I only notice it on vehicles when the 3rd light and the main brake lights use the opposite technology (one LED, the other incandescent).
