Sun D228
ws9876
Solar Expert Posts: 453 ✭✭✭
this looks like the best lowcost sub pump for a 120ft well. If it was used to fill a 300 gallon plastic tank slowly....what happens if
the water level runs dry for a little while while recharging??? will the pump shut off and wait??? Solar panel power. I use about 50 ga per day but could get that way down if needed..my well is about 4-6 gpm I think....
Re: Sun D228
you might look into a safety (low flow) shut off, if the water level drops too far it cuts the power.
hth
Re: Sun D228
the 228 is a diaphragm pump. are there equivalents that arent??? is it hard to rebuild diaphragm insides..??? -
Re: Sun D228
I have some experience with diaphragm pumps and wouldn't recommend them for a well.
While they are easy enough to work on, just pulling them and putting them back down can be a pain.
You will need a low water shut off with any pump, I suggest looking at Grundfos or Lorentz. More expensive, but much more reliable in my opinion.
