6 Volt Battery Charger/Equalizer?
silvertop
silvertop Solar Expert Posts: 155 ✭✭✭✭✭
I occasionally, have a need to grid charge 6 Volt deep cycle batteries, one at a time. Does anyone know of a 110 charger for 6 volt that also has an equalization function? As I recall, my local battery shop has a charger that has a reastat to adjust the voltage. Maybe this would be an option? Suggestions.....ideas???
    Re: 6 Volt Battery Charger/Equalizer?
    My guess--Something like this is going to be your "off the shelf" option:
    http://www.amazon.com/Schumacher-PSW-61224-ProSeries-Battery-Charger/dp/B002YK9ZYQ
    It will be up to you to set/monitor the equalize current you want and to set/monitor the time.
  • silvertop
    Thank you for the link. I can't tell if the voltage is adjustable with this manual charger. I will have to research it later. I'm looking to raise the voltage for a true EQ, not just continuous manual current.
    From reading the specifications--It almost sounds more like a charger where you set the current you want. I.e., 6 volts with heavy current is a light current at 12 volts (if I recall the manual correctly). It did not have a specific voltage set point--just timer and current settings (again IIRC).
