Wind turbine charge controller
Good day folks,
I wonder if I can use a MPPT 24 volt solar charge controller on my wind turbine are they interchangeable? Thanks for the feedback.8)
Re: Wind turbine charge controller
It depends
Midnight Classic series and Morningstar MPPT 45 & 60, have WIND options. (which would also be HYDRO too)
But you have to look at the turbine output, and make sure the peaks/spikes NEVER exceed the allowable DC input voltage. Many turbines have multi-phase AC generators, which need to be rectified and filtered a bit, before a MPPT can use it.Powerfab top of pole PV mount | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
