What do I need?
Hi guys. This is my first venture into solar. Here is what I want to start powering by solar. I have a battery backup for my sump pump in my basement. I worry about an extended power outage and my battery runs down and the sump pump stops working resulting in a flooded basement. The battery is now being charged with a unit that charges the battery and is also the on/off switch for the pump.
What I have now is a Canadian Solar CS6P-230 panel and a Powerbright 2300 watt 12v inverter. Probably overkill for this application, but I will add some other uses later.
So, what else should I have to complete this system? Some product selections would be helpful. And how should it be wired up?
If this works, then I plan to do a whole house solar install sometime next year.
Re: What do I need?
Welcome !
First, a solar panel, while it's raining, will not extend the run time of the pump. Only a larger battery will extend run time. (or a smaller pump)
Is your pump 12VDC or 120VAC ?
Can you give us any numbers off the pump, battery and charger you have now ?
Sometimes, a marine / boating 12V bilge pump can work, but you have to make sure they can pump the volume you need, at the lift you require - some pumps are rated for 0-12' lift, 0-20 gpm, but at 12', you only get 1 cupfull per minute.Powerfab top of pole PV mount | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
Re: What do I need?
If you have reliable domestic water supply (i.e., not a well pump on utility AC), you can also find various water powered sump pumps (here is one--don't know anything about it or the vendor).
If I had one of those, I would have saved my hole in the ground central heater too when the float on my old/cheap sump pump stuck.
But, I got a better (and more efficient) furnace now (95% or so) and I put in a less cheap pump and float assembly (dual floats plus pump fail alarm).
Still have not gone the extra measure of a backup electric/water powered pump yet--probably not needed as long as I know the sump is filling (takes weeks to over flow).
Re: What do I need?
Hi again. I thought it was clear in my original post that the pump was a 12V DC pump. The battery is a Marine battery with 750 cranking amps. The pump should run for hours on the basttery alone. My concern is if I am out of town for 2 or 3 weeks and the power to the house is down, I want the solar panel to charge the battery.
I think it is a simple as hooking up a controller to the solar panel and to the existing battery. Right??? If so, what controller would be a good one for this situation? -
Re: What do I need?
You talked about a 12 VDC inverter--I was not clear if you where looking for a second 12 VDC pump or just use your inverter for power.
A 12 VDC pump will probably be much more efficient.
750 Amp cold cranking rating still does not tell us much about the battery. Marine batteries do not make great deep cycle batteries--but for light usage, it may be the best bank for the buck for your application.
Assuming your battery is 100 AH at 12 volts, and we recommend 5% to 13% rate of charge, then a good choice would be a 10% rate of charge and assume 77% panel+charger derating:- 100 AH * 14.5 volts charging * 1/0.77 derating * 0.10 rate of charge = 188 Watt solar array
- 100 AH * 14.5 volts charging * 1/0.77 derating * 0.05 rate of charge = 94 Watt solar array
- 94 watts * 1/12 volts * 0.62 system derating * 2 hours = 9.7 AH per day
A "inexpensive" higher end bilge pump will do:Continuous Duty. Submersible with 6' Tinned Wire Assembly. Removable Cartridge. Tough Nylon Housing. Exclusive Quick Snap Swivel Base. Ignition Protected. ISO 8849.
12 volts, 3.2 amps.
Dimensions 4.5" X 3"
Footprint 2 3/8" Round [86mm]
Flow @ 0' 1000 GPH - Flow @ 3' 840 GPH - Flow @ 6' 650 GPH
Port Size 1 3/8" Fuse Size 6.0 A
Besides battery, will also operate from a solar panel that can supply about 3.2 amps or more- 9.7 AH per day in December * 1/3.2 amps = 3 hours per day with 94 watt panel charging your battery bank
PS: A 100 AH battery will run around:- 100 AH battery bank * 0.80 useful capacity / 3.2 A pump = 25 hours
Re: What do I need?
BB
Thanks for the input. You obviously know your stuff.
You said "So, without sun, your battery would supply around 25 hours of pumping (with 80% capacity factor)"
Is that continous runnig? My pump in a severe rain (very rare) will run for about 2 minutes every 5 minutes or so. It normal is about a 2 minute run evry half hour or so. My pump is similiar to your example, about 3 amps.
I am looking for a recommendation of what controller I should be using. -
Re: What do I need?
IF your battery is rated for 100 AH and was deep cycle (Marine batteries are not deep cycle batteries and if they get deep cycled, will not last very long), then yes, about 25 hours (20 Hour Rate is what we use around here for most solar applications). The 80% is assuming the battery can lose 20% of it capacity (aging/sulfating) before you recycle for a new one.
So, assuming 4 minutes per hour, 80 AH usable capacity, 3 amps, then you would be looking at:- 4 min per hour / 60 min per hour = 0.067 hours per hour of operation
- 80 AH * 1/3 amps * 1/0.067 Hours run time per Hour = 398 Hours
- 398 Hours / 24 hours per day = 16.6 days without sun
Solar panel wise, you would need (assuming 2 hours of sun per day, 0.62 eff, 3 amps with a 0.067 duty cycle:- 3 amps * 14.5 volts charging * 24 hours per day * 0.067 duty cycle * 1/0.62 sys eff * 1/2 hours per day sun = 56 watt solar panel
Battery wise, a 56 watt panel with 5% to 13% rate of charge, and picking 10% rate of charge as a good number:- 56 watts 1/14.5 volts * 0.77 derating * 1/0.10 rate of charge = 30 AH @ 12 volt battery bank.
However, you can use a smaller solar panel and still keep the battery well charged.
More or less up to you what is important in your situation (15+ days of battery only pumping or 5 days).
Charge controllers... For smaller panels (that have Vmp~17.5 volts), any good quality PWM controller should be fine.
If you want to spend a bit more money, you want a 3+ stage controller with "Float" (which cuts the charging voltage from 14.5 volts to 13.5 volts or so). Batteries will use less water and may last longer, especially in your case, when using a float charge stage (less "boiling" of the electrolyte).
Simple charger (no float)
SunGuard 4.5 amp solar charge controller
This guy below has a "sealed" battery setting (sets to 14.1 volts--better for longer term service in your case with flooded cell and rarely used):SunSaver 6 amp solar charge controller
And this one has a true Float Stage (not real cheap):ProStar 15 solar charge controller
For an AC backup (or primary) charger, a Battery Minder brand unit is pretty nice (I use one on a car that does not get driven very often and it works well).
I got this Battery Minder and it seems to work well (usual disclaimer--sample of one on in-laws' car).
At some point, to be cost effective, a solar panel + charge controller + small battery (plus a small charger) vs a Battery Minder + larger battery and no solar backup is a tough call.
On thing you will need too is a way to monitor/test your system. You don't want to find out 4 years down the road you find the the backup pumping system because of a failed charge controller, pump, or battery...
- 227 Forum & Website
- 618 Discussion Forums/Café
