2 charge controllers in series
ws9876
Solar Expert Posts: 453 ✭✭✭
Can you use 2 cheap C 40 controllers in series to get 80 amps of input..???? As an alternative to a big expensive controller....
How would you wire that..???
Re: 2 charge controllers in series
You wire multiple controllers in PARALLEL, just like you would wire 2 inverters.
Each controller would have it's own solar array, but feed the same battery bank.Powerfab top of pole PV mount | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
You cant get them to work if you wire them in series.You have to wire them as Mike said in parallel.. half the panels on one controller and the other half on the other one and the controller outputs connected together at the batteries. -
What happens if you put the air-x thru a solar charger, with the reg. all the way off? I wont try, I am afraid Ill break it.Always troubleshoot with adequate sunlight. Hi Ho Hi Ho
2.3kW [10] Enecsys SMI-240-60 micro inverters -
You cant successfully use a solar charger on a wind generator. THE END -
I didn't think so, so I didn't, thanks. Do you know how to arrange the stator wires wye or delta to the rectifier? The air-x, after all has it's own, though simplifiing..Always troubleshoot with adequate sunlight. Hi Ho Hi Ho
Here is an example of 3 phase Wye connected rectifier:
http://www.allaboutcircuits.com/vol_3/chpt_3/4.html
PS: Here is a short thread from Windynation showing how to wire up three diode bridge sets:
http://www.windynation.com/forum/3-phase-rectifiers-t489.html
-BBNear San Francisco California: 3.5kWatt Grid Tied Solar power system+small backup genset -
O.K. what is the composition of the three outputs that can be terminated any which way onto the rectifier? I am looking at 6 outputs 3+ and 3- from the stator not 3
I am gathering that they can be connected ina wye (constant amp variable volt, I do not think ssw chose this) or in a delta serial connection, I know direct serial does not work, only binds. I think I could play with it forever different "steppe" series, I really want to do this tough!Always troubleshoot with adequate sunlight. Hi Ho Hi Ho
The actual stator windings output is AC, and has no constant positive or negative polarity. It would be configured as Bill described.
If you have three positive and three negative outputs then it has already been rectified to DC and the only way to connect them is in parallel. This is normal for an alternator.
