Xw xantrex 4024
Kefalonianman
Solar Expert Posts: 60 ✭✭✭✭
I am trying to update my firmware via the gateway modem and I keep getting the file name is not recognised
Has anyone out there completed this task and can give me some pointers
Many thanks paul
Many thanks paul
Re: Xw xantrex 4024
I have, it works. You need a special file from tech support. The ones you can download from the web site wont work with the gateway. -
Re: Xw xantrex 4024
Joe
Many thanks for your reply, can I ask why you updated my problem is that the inverter will no longer accept mains voltage and keeps turning on and off have you ever heard of this
Many thanks again
Paul -
Re: Xw xantrex 4024
I updated mine to get a new feature called gen support plus. Your problem of not accepting mains voltage does not sound like it will be fixed by a firmware upgrade.
