Latest 19k hybrid install
xolar
Solar Expert Posts: 27 ✭✭
We have been busy trying to beat the rain and got the bulk of the install done so I thought I would share some pics.
The system consists of 84 CS6-230P modules 3 SB6000us inverters,
4 sunny island 5048 battery based inverters and some creative wiring.
I am waiting on a 20kw John deere generator and 24 full river DC400-6 batteries
that will be inside a DPW enclosure.
Enjoy
Enjoy
Re: Latest 19k hybrid install
That looks awesome!
Where is all the shading coming from on the bank of panels on the right? -
What is the application?
T -
The shade is late in the day from a large tree that is being removed and the application is a large residence outside the city limits. -
Very nice work!!!!!!!!!!!!!!;) -
i'm jealous.8)
heck, i think the ground area those pvs take up might be as large as, if not larger than, my entire lot.:roll::D -
I had to do quite a few work around's to make this system work, I'm not to sure how many people out there have done a full sunny ac coupled system but they have there complex parts. Here is a semi current diagram I need to change a couple as built changes but it explains the path. -
Attachment not found.Well I got the system all up and running and thought I would share a few pics of the finished productAttachment not found.Attachment not found.Attachment not found.Attachment not found.Attachment not found.Attachment not found. -
One other cool quick system I did was for Mr. Haggard to power a sqflex well pump I think it turned out pretty sweet, I am currently putting in a 12k grid tie on his new studio to be.Attachment not found. -
Xolar,
Regarding your 19K hybrid installation ...
What brand is the solar mounting kit?
The vertical pipe looks like galvanized fence pipe?
What are the square tubes made of? -
The racking is pro solar and the galvenized pipe is 1 1/2" galvanized thick wall water pipe. The horizantal pipes are supported with Hollander tee fittings. -
The installation is all top notch, best I have seen.
I am concerned though, it appears you have connected three strings of batteries in parallel, which is a serious safety violation. Each string must be fused so a fault of a battery doesn't cause a fire or explosion with the other battery banks feeding the fault unprotected. -
I have already ordered fuses for the cables to protect them I had to do some flex and roll with my initial design because of cabinet issues. I like the design of the new outback cabinet and will be using that type of setup in my next system with 9 sunny islands and all custom designed enclosures. I'm working on a multicluster tower based setup up that I think will look super neat.
I would really like to team up with some one a come up with a better GUI for the sunny island system, I'm not to sure how many people out there are trying to data log with the web box/non portal but there are not a lot of options.
Really there is a serious lack of information reguarding the SI platform, what I really liked about this was the ability to power some high current loads directly from the ac/pv without little assistance from the batteries or sunny islands.
Jason -
Where is this located? You don't appear to have a location specified in your profile. -
Both the job and I are located in Redding, CA
- 234 Forum & Website
