AC to DC charging question
TDSolarguy
Solar Expert Posts: 31 ✭✭
Greetings All
I just bought a 45 AMP Power Max AC battery charger from our host at Arizona Wind & Sun.
http://www.solar-electric.com/pomax12vo45a.html
I want to keep my batteries charged up during the long overcast days this winter. I read through the instructions and I cant find any information on weather I can use my Power Max charger while my Solar charge controller is connected to my panel and battery. I read through my Charge controller manual and no mention about it as well. I have a Morning Star SunSaver 10 AMP solar charge controller. Do I need to disconnect my Solar Charge controller and Inverter before giving my batteries a charge with the Power Max Charger?
TDSolarguy
TDSolarguy
Re: AC to DC charging question
Not a problem.
Both charge sources are regulated (albeit differently) and neither will interfere with the other.
Bulk it up with the Power Max and let the panels do the 'finish charging'. -
Thank you so much Cariboocoot.
You have been a great help. I also took your advice on a previous post and ordered a 100 watt panel for my modest 75 AMP batteries. I am having a blast with learning Solar and learning from this site.
Regards
TDSolarguy
- 231 Forum & Website
