Retrofit to Battery Back Up?
stoneunhenged
Solar Expert Posts: 39 ✭
My plan is to build a PV system that feeds into the grid but eventually add a battery back up system. How difficult would the retrofit be? What type of components should I buy now with the retrofit in mind? Thanks for your help.
Re: Retrofit to Battery Back Up?
I'll suggest you look at SMA's Sunnboy GT inverters: http://www.solar-electric.com/smasugrtiein.html
Then for battery back-up you can add their Sunny Island unit: http://www.solar-electric.com/suis5050waba.html
Pricey, but designed to do just what you're after. -
If you are going grid tied first, then hybrid later (with batteries)--You can either look at the Sunnyboy Marc suggested, or look at a pure GT inverter and later getting a XW or other Hybrid inverter that is compatible with your pure GT inverter (back feed the XW/Hybrid inverter to recharge your battery bank).
I would be a little hesitent to make big plans this way... The hardware goes through an evolution about every 5-10 years--and it is possible that whatever you planned for today may not be available or totally different 5-10 years out.
If you plans are closer in--You may want to save up and go Hybrid right out of the gate now. You probably will have more tax credits and rebates now than you will in five years.
But--this is a big commitment. In general, if you are looking for emergency/backup power, a genset will probably cost you a lot less money and be easier to move from home to home (and just install a pure GT solar system for now--much cheaper and depending on where you live, you may actually save money).
I went back and forth trying to find a way to do what you are talking about for two years. It is almost an impossible decision due to the nature of the lifecycle of electronics. Any way you go you will end up with some equipment you won't use down the road.
My final decsion was to build an offgrid setup and get it operational and running a couple of rooms in my house. I will continue to buy panels with the gameplan being to get enough panels over the next couple/three years to do a hybrid system. This way I can buy the panels as money permits. As time passes my required number of panels can change so I am not locked in to a rigid layout. Once I get to the point I have the required panels, I will then look at the current batch of inverters to see what is worth buying.
Getting similar panels is the most common problem of a long term build. They way my thinking goes is that my original panels for the offgrid setup could be used later in the tied setup if needed. The inverter,CC, and batteries can always take a different set of panels if I choose to keep them active, or they could be used to step down the hybrid batt bank and run a 12v or 24v sub system.
Like said above, what you are actually going to do with the system will determine what is the best way for you to go.
good luck!
Seven. -
Re: Retrofit to Battery Back Up?stoneunhenged wrote: »My plan is to build a PV system that feeds into the grid but eventually add a battery back up system. How difficult would the retrofit be? What type of components should I buy now with the retrofit in mind? Thanks for your help.
"It ain't cheap, though."
Boy is that ever right!
But neither is buying a Xantrex MPPT80-600 which can take a high Voltage GT array and charge a battery bank, which would be another option (around $2,000 just for the controller & its associated bits).
There's no cheap way to do solar and get good results. Every time someone tries to "save money" they end up on here saying "my system doesn't work: help!" :roll: -
I assume this is to have backup power in case of a power outage?
If so, then I'd recommend buying Enphase inverters and adding a cheap generator. The nature of Enphase micro inverters and cabling losses means that they work well with generators. When the sun is out the generator just idles and the inverters provide the bulk of your power. If the inverters are producing more power than you need they will shut down one at a time and regulate output power.
Note: Enphase does not endorse using their inverters this way, but several people near me have tested this with no problems.
The big problem with hybrid inverters, other than the large initial cost, is the cost of battery up keep. You waste power keeping the batteries charged up, you waste power going through the chargers/charge controllers, and even if you never use them you have to replace the batteries every few years as they die of old age.
You can pick up a generator for substantially less than the cost of upgrading to a hybrid configuration and that's without including the cost of batteries.
The cost of replacing your batteries every 5-6 years would buy a couple more generators.
Unlike batteries, generators rarely die of old age when not being used.
Oh yeah, if you're buying panels now and storing them for future use, I'd just save up the money instead. The price on PV panels has been plummeting lately, today they cost less than 1/2 of what they cost 2 years ago and it looks like they will drop even more. -
Re: Retrofit to Battery Back Up?If so, then I'd recommend buying Enphase inverters and adding a cheap generator. The nature of Enphase micro inverters and cabling losses means that they work well with generators. When the sun is out the generator just idles and the inverters provide the bulk of your power. If the inverters are producing more power than you need they will shut down one at a time and regulate output power.
One problem with that is generators are very inefficient at idle, so you are wasting a lot of gas essentially duplicating the generating capacity.4.5 kw APC UPS powered by a Prius, 12 kw Generac, Honda EU3000is -
Re: Retrofit to Battery Back Up?If the inverters are producing more power than you need they will shut down one at a time and regulate output power.
I have real doubts about this claim. The inverters would have to be shutting down based on overvoltage. Not a good way to run.
Only an inverter/generator would likely provide suitable frequency stablity to even keep the GT inverters reliably on line. -
Re: Retrofit to Battery Back Up?I assume this is to have backup power in case of a power outage?
- 231 Forum & Website
