Magnum inverter
ws9876
ws9876 Solar Expert Posts: 453 ✭✭✭
People say the Magnum is good in part because of the price and the battery charger onboard.... does their charger make it unnecessary to have a charge controller..????
    BB. Super Moderators, Administrators Posts: 33,712 admin
    Re: Magnum inverter
    Generally inverter + charger is an AC battery charger. It does take the place of a solar DC battery charger.
  • Vic
    Re: Magnum inverter
    If you have PV input, you will need a Charge Controller.
    The Magnum on board charger that runs from the grid or generator is well-regarded. One of the reasons for this regard is because it is Power-Factor corrected. This is more kind to a generator, making better use of its output capability
    I have no experience with Magnum, but a number of members here use them.
    Vic
    Re: Magnum inverter
    as was basically said the charger is for the 120vac input power and not a dc input from pvs. controllers normally address a dc input voltage usually from a renewable power source.
  • solarvic
    Re: Magnum inverter
    I just bought one last week. Manual shows that you can supply it with either 120 or 240 v. I understand that you can charge with 120 and get 220 out if read the manual right. :Dsolarvic:D Ps I will have more questions. Ordered a classic 150 yesterday.
