12vdc laptop charger fuse?
MichaelJ
Registered Users Posts: 23 ✭✭
Greetings,
I hope this isn't too far off topic, it is solar related.
The primary reason for a Kyocera 135w panel, cc, and 12v battery is to be able to recharge my wife's laptop.
Received the Pwr+ brand charger with no manual. Checked the fuse in the automotive plug, found 15 amp. The charger is rated: input 11.5 - 16vdc 5.6 amp max, output is 19vdc 3.42 amp (65 watts).
Why a fuse 3 times the max input amps? Isn't a fuse there to protect the charger and laptop, or am I just missing something?
Thanks, Mike
Thanks, Mike
Re: 12vdc laptop charger fuse?Why a fuse 3 times the max input amps? Isn't a fuse there to protect the charger and laptop, or am I just missing something?
Essentially, fuses are installed to protect wires from overheating. -
Thanks drew4justice,
You're right of course. I have some experience with residential wiring (12ga-20a, 14ga-15a), but I suppose if the charger fails, it would exceed 15a.
Mike
