Adding 2 more T-105's - Wiring Diagram?
boywonder
Registered Users Posts: 16 ✭
I have just purchased two more Trojan T-105's w/ 4/0 (welding cable) connection cables. I'm adding them to the existing 4 T-105's I already had for a total of 6 (the existing 4 batteries are only a month old).
I'm wondering if the enclosed diagram I made is correct?
Also, are there any precautions I need to take while wiring these in? Do I need to dis-connect or turn anything off while making the connections?
Any and all help appreciated.
boywonder
boywonder
Re: Adding 2 more T-105's - Wiring Diagram?
Are you looking for 18v? If not this is not the correct wiring.
I am a newby so I could be wrong,
Greg -
Greg,
Thanks for the reply.
This is for an RV setup so I'm assuming it needs to be 12v.
Thanks,
boywonder -
Adding this attachment diagram of existing 4 battery setup.
boywonder -
OK, as I said I am a newbie. I rethought about your first diagram and it would work.
Sorry,
Greg -
Re: Adding 2 more T-105's - Wiring Diagram?I have just purchased two more Trojan T-105's w/ 4/0 (welding cable) connection cables. I'm adding them to the existing 4 T-105's I already had for a total of 6 (the existing 4 batteries are only a month old).
boywonder
That will work, but use bus bars instead:
The reasoning is that this way there is no question that each battery pair is seeing the same charging current. With them wired as a string there will always be small variations. -
even if you use a buss bar, feed from opposite corners .Powerfab top of pole PV mount | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
I'm very new to solar and not yet familiar with all the terminology. Would the below image/example be correct using "buss bars" and "feed from opposite corners"???
Can the Buss Bars be purchased at a electrical supply or perhaps Home Depot or Lowe's??? I've found some on eBay but we are traveling in an RV and usually don't stay in a location long enough to have stuff shipped.
Really appreciate everyone's input and I apologize for being so "Green" at this, but I am learning as I go.
Also, reverting back to the original post, do I need to take any precautions such as turning everything off and dis-connecting anything prior to adding in the 2 new batteries???
boywonder -
if going to a place like lowes you can use something like this,
http://www.lowes.com/ProductDisplay?partNumber=71794-1318-ECLX072M&langId=-1&storeId=10151&productId=3180689&catalogId=10051&cmRelshp=req&rel=nofollow&cId=PDIO1
now that may not be large enough so you could just use a good bolt and nut with washers and bolt all 4 wires for each polarity together.
both of these assume you to use equal wire lengths from the battery to the bus or bolt to distribute loads and charges evenly.
if going to naws this can work too,
http://www.solar-electric.com/16220-1.html -
Our favourite standard reference for battery bank wiring, SmartGauge: http://www.smartgauge.co.uk/batt_con.html
And yes, do shut everything down so there is no current flowing in or out when you try to change battery wiring!
For best results (maximum safety) each battery string should have its own fuse before connecting to the common point. -
Thanks Jagec. I may use that configuration if I move up from 4 batteries to 6.
http://www.trojanbatteryre.com/DataSheets.html
http://i54.tinypic.com/29zpzd5.jpg -
I went to Lowes and purchased aluminum strips. They are 1/8 by 1 1/2 inch. They have different sizes. I just drilled the right size hole to fit the battery posts. My post are on the top on T-105’s. Seemed to work ok so far. Don’t know of any reason aluminum can’t be used in battery box. If so someone speak up. -
Aluminum forms an oxide on surface in seconds to minutes so is very difficult to make good electrical connections.
As the connection corrodes, the connection heats up, the aluminum expands and cold flows around the fasteners. The current flow stops, the aluminum cools and pulls back, allowing more corruption to form.
Eventually the connection will fail. Many house fires have been caused by aluminum electrical wiring "properly installed" around 40 years ago.
- 651 Solar Water Pumping
- 611 Discussion Forums/Café
