150V wind turbine motor
edanthony
Registered Users Posts: 7 ✭
I wonder if I can use a 150VDC PM wind turbine motor on 12V or 24V battery bank without harming the battery? Thanks for the feedback.
Re: 150V wind turbine motor
You can... Assuming the battery is capable of absorbing the current (i.e., battery is around 8-20x the current output of the motor--I.e., a 10 amp motor * 10 would be a 100 AH battery bank) and you have a diversion/dump charge controller that turns on a dump load (typically a resistance heater) to keep the battery from over charging.
One issue with running a high voltage PWM motor at 1/10th its output voltage is that you also get 1/10th the capable power of the motor (i.e., 10a*150v=1,500watts vs 10a*15v=150watts).
If you want to make a DIY wind turbine, there is lots of information and a forum over here:
www.otherpower.com
I run 180 volt PMDC motors for 12 volt charging,these are 1725 rpm 8amp motors and do a good job. -
Thanks for the info. 8)
- 621 Discussion Forums/Café
