Free bus bar wire for those fixing up laminates
meridiansolar
Solar Expert Posts: 34 ✭
I have some extra bus bar wire, probably enough to add tabs to about 20 panels left over from my project, if you want some send me your address via Private Message and I'll mail you an envelope with it.
Re: Free bus bar wire for those fixing up laminates
do you mean battery interconnection wires?
got pics? -
I think he means interconnects for cells when building your own panels. -
YES for fixing/making your own panels
http://solarcellwire.com/cellwire/index.php?main_page=index&cPath=2 -
Interesting piece on page 51 of the Oct/Nov issue of Home Power mag.
Should be required reading for anyone considering building their own panels.
I'll leave it at that. -
IT DOESn't make financial sens to make your own panels when you can buy them for 50 cents a watt with ripped off junction boxes and spend about two hours each to fix them with a junction box. k
interesting magazine though. do you recommend a subscription? -
Home Power is required reading (I would add Mother Earth to that list, too). They cover more topics than just PV/wind/hydro.4.5 kw APC UPS powered by a Prius, 12 kw Generac, Honda EU3000is -
especially when those .50 cent panels have odd Vmp so that you then negate your savings once you buy the required mppt controllermeridiansolar wrote: »IT DOESn't make financial sens to make your own panels when you can buy them for 50 cents a watt with ripped off junction boxes and spend about two hours each to fix them with a junction box. k
you can get 50 cent panels with 35v vmp, :roll:
- 226 Forum & Website
- 617 Discussion Forums/Café
