Local Zoning denied PV system
kodioneill
Registered Users Posts: 7 ✭
My local government just denied my PV design. Their position , it's a business
( because you're selling power back to the grid) in a residential zoned area. Three years planning, I have all the elements for an install and I'm shutdown right at the start . I live out in the country far away from setbacks and neighbors.
Re: Local Zoning denied PV system
If your local utility allows grid-tie with sell-back they might also have someone on staff capable of explaining the obvious to the local authority who seems a bit lacking in the intelligence department. Failing that, there is always the next level of government: if the State permits it (and in some cases they mandate it) then your local AHJ is in violation of state law for denying permission based on what can only be called "improper reasoning". If that proves a wash, perhaps a nearby TV station would like to do a story on how the local government is anti-ecology and in favour of everyone choking to death on smog.
Bureaucrats: give them even a small amount of authority and they will abuse it. :roll: -
You can look through the www.dsireusa.org website and see if there are any state/federal laws that would change the outcome for your system (commercial solar is a new one on me for denial).
where do you live? a letter to your city council would be the first step. state senator/house of rep would be next.
There might be a law that protects you from this BS. -
Are you trying to do this with home-made panels?kodioneill wrote: »My local government just denied my PV design. Their position , it's a business
( because you're selling power back to the grid) in a residential zoned area. Three years planning, I have all the elements for an install and I'm shutdown right at the start . I live out in the country far away from setbacks and neighbors. -
Re: Local Zoning denied PV systemkodioneill wrote: »My local government just denied my PV design. Their position, it's a business ( because you're selling power back to the grid) in a residential zoned area.
You didn't say what capacity your planned PV system was, nor
did you mention what your annual consumption is.
However, if your annual consumption is greater than your
projected capacity (using PV-Watts), then you could show them
the numbers which would show you as a net consumer, and
not a seller.
Can you tell us your current consumption, and your planned
PV capacity, both in kwH/year?
John -
Re: Local Zoning denied PV systemYou didn't say what capacity your planned PV system was, nor
not a seller.
John
Usage is almost at parody with production. 7kw -
Re: Local Zoning denied PV systemAre you trying to do this with home-made panels?
Re: Local Zoning denied PV systemrollandelliott wrote: »where do you live? a letter to your city council would be the first step. state senator/house of rep would be next.
Up state NY near Saratoga. No neighbors out in the country. -
Perhaps it's governments latest way of raising more money, change homeowners with "free" electricity over to commercial with it's far higher tax rate, then sock it to them. Solar power is as good an excuse as any. -
http://www.dsireusa.org/incentives/incentive.cfm?Incentive_Code=NY01R&re=1&ee=1
this web site is pretty much worthless,
the easiest thing would be to go to town meeting and request your home be rezoned residential/commercial.
Peace, Rolland -
Re: Local Zoning denied PV systemrollandelliott wrote: »the easiest thing would be to go to town meeting and request your home be rezoned residential/commercial.
I would suggest you find out first what difference it would make to your property taxes. Have no idea how things work where you live, but here the commercial rate is at least 3 times that of residential, and in some locations a lot more than that. -
Have you talked to anyone from your power supplyer? That was my first step in Pa. They sent me info on what they required and a link to the public utility commission for PA. I think your state should have a public utility commission. All the laws are spelled out there. :Dsolarvic:D http://www.powernaturally.org/about/library.asp Here is a link I found for your state of NY that has a lot of info you might read up on. -
I agree, my first next call would be to the power company. I know a couple things..... one, the denial of solar is absurd. Two, you get more flies with honey. I feel confident that you will be allowed to have your solar, but you may need to find a way to make the town feel good about it. Calling them the idiots that they may well be is not going to help this process. You need to fluff their feathers and get them to feel all fuzzy inside when they say yes. Once the power company explains to them that the Feds require net metering (they do, don't they? I've always heard that), that it's not a net sale, it's a trade. and that solar arrays such as you have planned actually help keep rates down, perhaps they will start to get that fuzzy feeling.
Even if it were a business, around here we are allowed "home occupations". That's another angle to look at. Unless a homeowners agreement prevents it, last I knew a town can not prevent you from earning money from your home. They can prevent you from having customers coming to your home, they can prevent signs on your property, but they can not stop you from earning a living. -
Typically the goal is not commerce but merely to lower your utility bill. You're really just using the grid like a giant free battery, giving them power when you don't need it so you can get it back from them when you do. So long as the utility is not actually cutting you a check, I can't imagine that you'd have to report the power you "sell" to the IRS or any other taxing authority.
Now if your goal *is* commerce and you don't actually use any grid power and the utility cuts you a check every month, well, that's another story. -
Re: Local Zoning denied PV systemEven if it were a business, around here we are allowed "home occupations".
Selling tea cozies on ebay from your home is one thing, but making business-related changes to the exterior of your home would certainly fall under your local zoning authority.
Amassing credit (for power) from your local authority is not exactly the same as having them cut you a check. But it's the sort of distinction that's lost on your average bureaucrat. -
Re: Local Zoning denied PV systemSparkletron wrote: »I can't imagine that you'd have to report the power you "sell" to the IRS or any other taxing authority.
You most certainly do if your annual production results in a profit. This is another reason why having a separate meter is problematic as your paid monthly for the revenue.
I would wonder if the OP is true net metering or dual meters, the later I could see where the zoning might classify that as a commercial enterprise. Unforunanlty, I don't see this as being a simple issue to resolve. -
Hummm, wonder how long before the "income" from grid-tie will need to be included with our income tax returns - - - -
Re: Local Zoning denied PV systemwaynefromnscanada wrote: »Hummm, wonder how long before the "income" from grid-tie will need to be included with our income tax returns - - -
As soon as the utility provides a 1099 form for us in the US. -
SRP requires a W-9 for the rebate. Is that close enough? -
Re: Local Zoning denied PV systemSolar Guppy wrote: »You most certainly do if your annual production results in a profit.
Actually, the IRS will be wanting the taxes on that profit in quarterly installments.
Define profit. I once paid a bill twice, resulting in credit. But power chits are not exactly legal currency. Hey! Solar power could be a great way to launder money! Simply convert ill-gotten gains to power and sell it to the utility for credit. Now we just have to work out how to convert that credit back into cash... -
Re: Local Zoning denied PV systemSRP requires a W-9 for the rebate. Is that close enough?
Yep nice that APS didn't! If they bother to issue one on the credit at year end so be it.
At least you could then claim the full 30% off the Feds, not just the difference between the price and rebate. Would have worked out to be a push pretty much for me. -
I would really like to see a copy of the denial. The actual text used in the wording. It is alot easier to overcome an objection like that by taking apart the body of the message and solving the parts individual of each other. Many times the actual wording is the easy part. If all that is stated is the business part, have them define business. No customers, no income, no employees, and no tangible product usually rules out a business.
Redefine "sell to grid" as "reduce consumption due to offset production value" in your request.
Be very specific in your wording also.
If you still have trouble, there are other ways to get it approved. One thing you must remember is that you must stay at least emotion free. Happy is better. The second you become an a$$, it is over. You can follow process and talk to board members individually in some cases. There should always be an appeal process, or a higher level of decision makers. Again, you can't anger anyone in the process. Saying "I'll go over your head" is not the best approach. Politely asking about the appeal process goes over much better. If they deny an appeal without merit, then there are some stronger steps you can take.
No matter how big a pain it is, you must follow their process structure. Stay calm and professional. -
Re: Local Zoning denied PV systemI would really like to see a copy of the denial. The actual text used in the wording. It is alot easier to overcome an objection like that by taking apart the body of the message and solving the parts individual of each other. Many times the actual wording is the easy part. If all that is stated is the business part, have them define business. No customers, no income, no employees, and no tangible product usually rules out a business.
Of course, what you may be up against is a prejudice against PV and the denial for it being a business just the excuse. Some folks just don't like the way it looks, or there may be a political agenda involved. -
That is why the actual wording is so important to his cause. If he corrects it as to the letter of denial and they deny again on other grounds, you can get into the realm of denial with prejudice. I think that is the proper term. Basically if they don't allow the install and keep changing the reason, they open themselves up for a complaint that actually gets reviewed at a higher level. It isn't worth the hassle on their part and they know it.
There are always other methods, but in this forum I will assume they are just misinformed on their decision. -
Re: Local Zoning denied PV systemThat is why the actual wording is so important to his cause. If he corrects it as to the letter of denial and they deny again on other grounds, you can get into the realm of denial with prejudice. I think that is the proper term. Basically if they don't allow the install and keep changing the reason, they open themselves up for a complaint that actually gets reviewed at a higher level. It isn't worth the hassle on their part and they know it.
- 194 Solar Information links & sources, event announcements
- 890 Solar Product Reviews & Opinions
- 612 Discussion Forums/Café
- 305 In the Weeds--Member's Choice
