string calculator
bobdog
Solar Expert Posts: 192 ✭✭
Is there a good yet understandable string calculator out there? I've attempted to understand SMA's version but with no luck. Any ideas? Thanks.
Tim
Tim
Re: string calculator
Each manufacturer has their own calculator.Powerfab top of pole PV mount | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
Re: string calculatorEach manufacturer has their own calculator.
Thanks. After more looking I figured that out. I'll go back and look at the SMA again. Thanks Mike. -
SMA recently updated their string calculator. Now its a "design tool".
I want the old one back - Anyone know where to find the old one?
The new one leaves out a lot of detail and doesn't allow you to print out the string results in detail. Won't even allow you to print out the on screen results.
One more reason to design in a distributed system and eliminate all the string size hassles. -
Re: string calculatorSMA recently updated their string calculator. Now its a "design tool".
My AHJ requires documentation of the string size. The SMA design tool shows the design results with string Voc etc. (doesn't show the options though of alternate string sizes like the old one did) but when you go to print it, you get a whole different page without any string details. Can't even do a screen shot. I talked to SMA tech support about it (and I'm in the SunnyPro club) and got a sorry, too bad answer. -
Re: string calculatorCan't even do a screen shot.
If you can display it in a web browser, you can always make a screen capture
snagit is a great tool for this -
Re: string calculatorMy AHJ requires documentation of the string size.
ALT-PrtScrn will capture the active window, in windows, paste into any graphic editor or excelPowerfab top of pole PV mount | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
Re: string calculatorWhat documentation will they accept if you do all the calc's by hand?
I'm a degreed engineer, but because I don't have a PE, they require proof from manufacturer. Legal liability mindset is behind this. Hey, why don't they require the coal industry to prove they are not causing global warming?
- 219 Forum & Website
- 127 Solar Forum News and Announcements
- 885 Solar Product Reviews & Opinions
- 649 Solar Water Pumping
- 606 Discussion Forums/Café
- 300 In the Weeds--Member's Choice
