24" oc rafters
![bobdog](https://us.v-cdn.net/6024911/uploads/customavatars/18/navatar_1018.gif)
bobdog
Solar Expert Posts: 192 ✭✭
Has anyone installed a solar system (grid tie or off grid) on a roof with 24" OC rafters? If so, was there anything special that needed to be done? Thanks.
Re: 24" oc rafters
It's all about structure.
Mine has 24" OC (Off Center in this case) rafters. But it also has 2" thick "sheathing".
Those rafters could be 2x4 trusses or 2x10 "snow load" beams. They could be sheathed with 3/8" OSB (yes, it's allowed here. I've no idea why) or 3/4" plywood. The distance between the rafters isn't the only factor, you see.
If you can access the underside (always a good idea if only for inspecting to see what's there) you can add structure as needed to be sure the panels can be supported. -
Re: 24" oc rafters
Unfortunately the only access would be to cut a hole in the roof or ceiling as there is no attic per se. It is a manufactured home with vaulted ceilings. However, I do believe they are 2x6 truss style rafters with a 20lb snow load. We get little if any snow here in southern NM. My guess too is it is covered with 3/8" to 1/2" sheathing of some kind.
Tim -
Re: 24" oc rafters
Can you walk on it? if so, is there much deflection?
Difficult to evaluate structure if you can't get a look at it. Manufacturer's specs might include full info. At that point you'd probably need a structural engineer to determine if it's feasible.
- 651 Solar Water Pumping
- 611 Discussion Forums/Café
