24" oc rafters
bobdog
Solar Expert Posts: 192 ✭✭
Has anyone installed a solar system (grid tie or off grid) on a roof with 24" OC rafters? If so, was there anything special that needed to be done? Thanks.
Re: 24" oc rafters
It's all about structure.
Mine has 24" OC (Off Center in this case
) rafters. But it also has 2" thick "sheathing".
Those rafters could be 2x4 trusses or 2x10 "snow load" beams. They could be sheathed with 3/8" OSB (yes, it's allowed here. I've no idea why) or 3/4" plywood. The distance between the rafters isn't the only factor, you see.
If you can access the underside (always a good idea if only for inspecting to see what's there) you can add structure as needed to be sure the panels can be supported. -
Re: 24" oc rafters
Unfortunately the only access would be to cut a hole in the roof or ceiling as there is no attic per se. It is a manufactured home with vaulted ceilings. However, I do believe they are 2x6 truss style rafters with a 20lb snow load. We get little if any snow here in southern NM. My guess too is it is covered with 3/8" to 1/2" sheathing of some kind.
Tim -
Re: 24" oc rafters
Can you walk on it? if so, is there much deflection?
Difficult to evaluate structure if you can't get a look at it. Manufacturer's specs might include full info. At that point you'd probably need a structural engineer to determine if it's feasible.
