Controller for 550pw panel
Hello
I am going to try a pile of broken cells that still output at 550 peak watts.
If that is a 12 volt grid (?) will a 30a controller work?
Re: Controller for 550pw panel
Typically, a 12 volt PWM controller operates with Vmp~17.5 volts.- Amp=Power/Voltage= 550 watts / 17.5 volts = 31.4 amps
If this is a true MPPT controller, then it would regulate to ~30 amp maximum (safely).
Thank you so much and as I expected - it's getting expensive
- 230 Forum & Website
