Renewable energy engineer
SolarLurker
Solar Expert Posts: 122 ✭✭
I need an engineer to draw up some plot plans and documents, can anyone recommend a firm with reasonable costs?
Re: Renewable energy engineer
I'd suggest check with solar installers in your local area, and see who they recommend.Powerfab top of pole PV mount | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
Where are you from.
I have a friend that is editor in Arizona Solar Center.
You can contact them on this page http://www.azsolarcenter.org/about.html
They have dedicated engineers for that. -
What exactly are you looking for? do you have the basic information on the plot map, and an equipment list. Also what are you expecting to pay? I do all of my own design and permitting and may be able to help you out. I can do a standard single line but prefer to do the single lines like the example below contact me if you still need help.
Jason
