Charging without a Charge controller
westbranch
Solar Expert Posts: 5,183 ✭✭✭✭
I have a need to connect, short term, a PV or 2 to my camper battery. We are demolishing our old cabin and using the camper for sleeping in, a bit of cooking and showers etc... both my CC's are still in use and I don't want to buy another one for this temporary setup.
Is there a rule of thumb to use for this hookup?
~ 660 amp battery, 25 W and 70 watt panels available. not direct sun as in the shade.
thanks
Eric
thanks
Eric
Re: Charging without a Charge controller
panels in the shade will never charge a batteryYou have more chance, without a charge controller, of the panels discharging the batteries at night (backfeed)
660A of battery, 100W of panel, even in full sun, you won't keep up with self discharge.Powerfab top of pole PV mount | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
Eric;
The only thing you can do is put a Voltmeter on it and watch. Together those two panels might produce 5 Amps? Not much for a 660 Amp hour battery (assuming the extra 'm' was superfluous), but even a small charge on a not-so-drained battery can push the Voltage too high. That's really all a PWM does; you'll have to stand in for connect/disconnect. But you don't have to do it dozens of times per second, okay? -
I have to ask a simple question. Is that battery a 660 amp hour battery or 660 cranking amps? At 660 Ah, that is a massive battery for a camper. Is it is 660cca, running a panel directly to it should keep it charged depending on the amp produced by the panel. I have a couple 100w panels hooked directly to a couple of marine batteries and the most I have ever seen them produce was 17a, and it was short duration.
***edit***
Be sure to run a diode if the panels stay hooked up an night. -
sorry, that is 660CCA as Leper pointed out. Probably in the ~100 A range of most car type batteries.
Ya, caught in the PV panel trap of hi Voltage/low amperage output.
It is a 'marine battery' used for the camper and the fishing trolling motor.
Just ordered a cheapo 10a PWM CC off Ebay. Now I can put the panels in the full sun without too much worry.
thanks for the quick comments.
Eric
Since that battery is a "hybrid" and contains the worst of both starting and deep cycle, avoid discharging below 70%, or you may not get started some morning !Powerfab top of pole PV mount | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
Mike I think you are confusing a camper with a "Winnebagel".:roll:;)
The camper slides on and off the pickup and has its own on board, independent battery, hence the 'marine type' as it is a bit better for long slow use... the main drawback is there isn't enough room for a couple of real deep cycle 6 volt batteries.
We only get about 2 days before needing to charge up. Water pump gets left on all day, Fridge and water heater are pilot-less units, the furnace fan is the big one and then lights and radio... oh and there is a magic fan that is temperature activated and the seldom used bathroom fan
- 227 Forum & Website
- 617 Discussion Forums/Café
