PVWatts hourly data
ggunn
Solar Expert Posts: 1,973 ✭✭✭
Does anyone in here know of a published Excel document which will graph out hourly data from PVWatts? I want to compare the hourly output of three slightly differently oriented subarrays to determine if they can be combined onto a single inverter.
My Excel chops leave much to be desired; if someone can explain to me in simple terms how to do it myself, that might work.
Re: PVWatts hourly data
I am not good at Excel... But you might try graphing the differences between the "nominal" and your Summer/Winter or Tracking/Non-Tracking differences (for example)... Graph the both differences and sum of the differences over time (by season or by year)--depending on how detailed you want the graphs.
That's what I was thinking, and I'm pretty sure Excel is the tool, but I know only enough Excel to generate a grocery list. ;^)I am not good at Excel... But you might try graphing the differences between the "nominal" and your Summer/Winter or Tracking/Non-Tracking differences (for example)... Graph the both differences and sum of the differences over time (by season or by year)--depending on how detailed you want the graphs.
-Bill -
Re: PVWatts hourly databut I know only enough Excel to generate a grocery list. ;^)
A grocery list of Solar, batteries, inverters and wires makes a mean salad if mixed well.
