Cell spacing
Electricsuperduty
Registered Users Posts: 8 ✭
I've searched, but I cannot find out if cell spacing is an issue. Can someone tell me if there is a minimum space allowed between the solar cells on the panel? I am using 6x6 with a glass area of 55.25 inches, so that puts them really close together, the other direction is fine.
thanks.
thanks.
Re: Cell spacing
None at all other then potential electrical shorts from them touching.
There is some consideration for thermal expansion on the tabbing between cells. Putting a little 'S' slack is good to avoid stressing connection to cell surface.
- 654 Solar Water Pumping
