Pool Solar problem
![System](http://northernarizona.vanillaforums.dev/applications/dashboard/design/images/usericon.png)
I live on LI, NY and had a Heliocol HC50 collectors installed last June 2010 by Sunshine Solar Technologies. It worked great heating my 12'X24' IG pool. The pool was closed in Oct. and the collectors were blown out for the winter. Upon readying for the pool opening this year (April 2011) I noticed that the collectors on the roof were damaged and chewed, rendering them unusable. Has anyone else experienced this problem? The installer hasn't gotten back to me as to his findings or a solution.
Re: Pool Solar problem
The only two issues I can see:
First, animals? Do you have problems with squirrels, rats, etc. in your area gnawing on wires/etc. in your area? Do the tubes look like they have been chewed?
Second, I wonder if the tubes should have been installed vertical in your area to better allow water to drain out. Horizontal runs of tubes like that would seem to be pretty difficult to drain for winter/hard freezes. Although, I would expect the material to be soft enough to manage frozen water (there was nothing in their web site I could find that discussed freezing/how to mount issues).
Have you talked with the installer/vendor yet?
Ouch, guess you have to use wire mesh next year.Powerfab top of pole PV mount | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
That's a very poor design, my solar for the pool is more like a sheet which the tubes are integrated into and another is completely flat are thicker. the ones you have no chance of lasting
Here is an example of what I have, the ones I bought were generic off ebay in 2003 and still work fine, think about 100 bucks a 12'x4' each
http://www.bakerlabs.com/solar/images/Solar%20Panel%20detail.JPG
The flat ones look like this, add in 2005 for more btus, fine as well
http://www.funpoolheating.com/FNS--Solar_Panel.jpg
Your are totally exposed with no support, they way they snapped could be snow/ice damage or even wildlife
BB, they are vertical, look at the shingles ... -
SG, I do believe you are correct. And I agree that small tubes exposed to weather (possible ice, snow, and small animals) seems like it is asking for problems. Notice that leaves are already stacking underneath.
Do you think the layout of the collectors might have something to do with the damage problem? I've only seem collectors attached to 'slanted' roofs or angled. I have always had problems with the roof design with debris, etc collecting in the V. I personally think it was a poor layout and should have been angled.
Any input would be appreciated. -
Just to give you an update.....
The Solar installer finally contacted me after 33 days and a nudge from the BBB. They will replace, reconfigure, etc at a cost to me of $650 (originally he wanted $950). Remember this install is not even a year old and under warranty!
What do you think? I say NO WAY! -
Re: Pool Solar problemJust to give you an update.....
Sounds like a small claims court time.
I looked at Helicool about 10 years ago for my pool. At that time the HOA would not allow it, and a good thing I think. One of my neighbors did install a setup and it lasted about 3 years on that roof, but I don't know the root cause for the removal, it may have been HOA related. -
Him, on reviewng your pictures, looks like an installation issue, with the V , your collectors can't drain and in a freeze will bust the little tubes in the cold weather
Not sure who made that call ...
New collectors will just have the same issue, you can't install in a V in a climate that goes below freezing -
Just to give you an update: We came to a compromise only because I wanted to get this behind me and get into the pool. I agreed to pay $500 for them to replace ALL the panels and reposition them to another part of the roof. The Northeast Distributor got involved, offered to put $ (as a good will gesture) towards the installers fee. I have since taken precautions with screening so as not to have this happen again. We are keeping our fingers crossed for next year.
We love having the warm water especially in the afternoons/evenings when the pool is shaded. Here's to another extended pool season.
- 651 Solar Water Pumping
- 611 Discussion Forums/Café
