Anyone familiar with SunSaver Charge Controllers?
bmet
Solar Expert Posts: 630 ✭✭
I received the 10 Amp version yesterday, installed it, and heard a mosquito-like whine. Is this normal operation? It seems to be working correctly, other than the annoying whine.
Thank you.
Thank you.
Re: Anyone familiar with SunSaver Charge Controllers?
That's normal. What you're hearing is the PWM oscillation.
Described here: http://www.morningstarcorp.com/en/support/item.cfm?ItemId=111
I put a video online a while ago showing what happens if you try to use a split ferrite to quench the noise:
http://www.youtube.com/watch?v=ffXBcXPQ9gc
I honestly only notice if I'm standing at the charge controller during the peak of the day. Not an issue for me at all. -
and also
http://www.morningstarcorp.com/en/support/item.cfm?ItemId=185 this is normal -
Thank you both for the confirmation. It isn't mentioned in the documentation that came with the unit, so I didn't think to look on the website either.
- 654 Solar Water Pumping
