How do I use this Solar Panel?
Alright so I'm making a solar powered car for a project and I have no idea how to use a solar panel. I left it out in the sun for a couple hours but when I hooked it up to a motor it did noting..................BTW it's a 1.5V Solar panel. Here some pictures to describe what I'm talking about. Any help on what I'm doing wrong would be helpful!
http://i978.photobucket.com/albums/ae270/Fatboy42/100_0651.jpg
http://i978.photobucket.com/albums/ae270/Fatboy42/100_0654.jpg
http://i978.photobucket.com/albums/ae270/Fatboy42/100_0652.jpg
Re: How do I use this Solar Panel?
1> a solar panel does not store electricity, only batteries do.
2> the pv will have to match the current and voltage required by the motor and be protected in some circumstances from over voltage if not using a battery.
3> the polarity must be observed.
4> realize that the power needed to move a ev is far greater than that little pv could ever hope to accrue in many months of charging a battery.
maybe i am misreading you on this on point 4 if this is for small models only, but the rest applies in any case. -
Try this site for small solar powered models, lots of fun if you are into building your own circuits or learning about it.
http://library.solarbotics.net/circuits/default.htm -
I have (2) 30 watt panels and connected them in series to a dc motor from a 12 amp vacuum cleaner. The motor was running at 1/4 power in other words at 3amps because that is all my panels will produce. Even at 3 amps, the motor was spinning the spindle like a champ. The Chevy Volt has a lithium ion battery that is 1.5kw capacity and has gas generator-assisted charging. The company says it will go about 30 miles completely off the battery before needing the gas to charge the battery. I would think that all maximum use of solar technology can produce a completely clean vehicle without any fuel whatsoever. That truly would revolutionize the automobile market! -
according to wikipedia:
According to General Motors the Volt can travel 25 to 50 miles (40 to 80 km) on a 16 kW·h (10.4 kW·h usable) lithium-ion battery;
16 kWh is a large amount of power, using a 220V 20 amp line the Volt takes 4 hours to recharge it fully. I have 72 solar panels covering most of the roof of my house and at noon on a good day it can product about 9 kw. Hardly a thing that could be placed as part of the auto.
PS still trying to get my volt to home base! and yes the solar will charge it. -
"I have (2) 30 watt panels and connected them in series to a dc motor from a 12 amp vacuum cleaner."
i hope you just misspoke here as 2 12v pvs in series will give you 24v. if they were paralleled then that will do it fine.. -
There's some fun solar powered toys here;
http://www.brilliantstore.com/solar-toys.html
Including a <$2 car (including shipping)Home system 4000 watt (Evergreen) array standing, with 2 Midnite Classic Lites, Midnite E-panel, Magnum MS4024, Prosine 1800(now backup) and Exeltech 1100(former backup...lol), 660 ah 24v Forklift battery(now 10 years old). Off grid for 20 years (if I include 8 months on a bicycle).
- 611 Discussion Forums/Café
