Estimating New Solar Farm project
GreenPowerManiac
Solar Expert Posts: 453 ✭✭✭
Looking for types of Solar panels (trackers or otherwise) to power a 500kw, 750kw or 1mw system on a farm.. Also the spacing required for all 3 farms. Is there an easy formula to determine spacing ?
Any suggestions for brand names of panels, inverters, or otherwise ?
Re: Estimating New Solar Farm project
500kw - 1mw per hour, day, year?
The you drop 3 farms, is this per farm?Home system 4000 watt (Evergreen) array standing, with 2 Midnite Classic Lites, Midnite E-panel, Magnum MS4024, Prosine 1800(now backup) and Exeltech 1100(former backup...lol), 660 ah 24v Forklift battery(now 10 years old). Off grid for 20 years (if I include 8 months on a bicycle).
Per year. Different size farms.
Looking for spacing between tracking equipment, good reliable brand names and formulas if available.Nature's Design & Green Energy on FaceBook : Stop by and "Like" us anytime.. Many up-to-date articles about Renewables every day.
Lots of DIY Renewable Energy Projects on ETSY : Solar Panel builds, Wind Turbine builds, Rain Barrel build,etc. -
PV Watts has a Ground Coverage Ratio chart for various mounting types (1/2 way down the page).
Nice 2 know. When Grid-tying, does the power company provide their own inversion system ? And what are some typical good brand names on stationary PV's ?Nature's Design & Green Energy on FaceBook : Stop by and "Like" us anytime.. Many up-to-date articles about Renewables every day.
Normally, the customer provides the solar array and grid tie inverter. And every thing up to the meter drop.
In many areas, under 10kW peak rated small systems bypass most "generator requirements for utilities. Over 10kW and you may hit a whole bunch of new requirements.
And, if this is a business with solar, the differences in billing / rate plans, can make business based solar economically unviable.
So much of solar depends on your state and utility rules, you need to check with a local installer or utility for details.
It sounds like you are looking at a 3-10kW system. is this to be a diy install or local installer?
- 230 Forum & Website
