Sailboat Solar Questions
System Posts: 2,511 admin
Good afternoon everyone, I am very new to solar installations, and I need some direction. I just bought a 37" Sailboat that I am getting ready to sail back to the Virgin Islands. The boat has a Xantrex 10 Charger and a Xantrex link 1000 monitor?Inverter. It also has 4-6volt Batteries making up its 24 volt system. It also has a seperate battery for the starting of the deisel engine. I will be running Refridgeration, Radar, Autopilots, but now all the time, and I have switch everything over to LED lighting. I am trying to see what I need for making up an easy, solar charging system. I have a stainless steel arch over the stern of the boat that would be perfect for mounting 1 large panel or possibly 2 small ones. I was thinking of something in the 125 watt range. I dont need to replenish every bit of energy used every day but I would like something that is reliable and effficeint. Thanks for all your help in advance.
    Re: Sailboat Solar Questions
    Welcome to the forum.
    Do a search for "sailboat" on the forum search. There are several threads including some dealing with mounting difficulties.
    To determine how much panel you need, you have to know the Amp hour rating of those batteries. Possibly they are Trojan T105's or the like: "golf cart" batteries. That's about 225 Amp hours. In that range you need quite a large array for charging:
    Minimum 11.25 Amps "peak" charge current (5% of battery capacity) * 28.4 Volts charging Voltage =
    319.5 Watts, less typical 77% derating = 414 Watts total.
    Are you sure it's a 24 Volt system? (All batteries wired in series). What sort of charging method is used now? Shore power only?
    Welcome.
    The real world problems are:
    1) fragile glass. any bending or twist will break the glass and your $500 panel is toast.
    2) marine enviroment. Most panels are not warranted for marine enviroments. So you would be on your own, with no coverage.
    Then there is the problem with shadows, the thin shadow from any stay or lines, will cut down your power harvest .
    These aren't unsolveable, but they do exist.
  • Elmer T
    Elmer T Registered Users Posts: 14
    Take a look in this section, "Solar Beginners Corner" and fine the Thread "Sailboat Application". It helped me alot with the same project that you about to do.
    Jeff
    BB. Super Moderators, Administrators Posts: 33,731 admin
    Here is the thread:
    Sailboat application
    Another thread:
    low-amp system for small sailboat
    By the way, an easy method to search the forum is to use Google and the "Site:" tag--Works much better than the forum search tool if you don't know exactly what you are searching for:
    • Sailboat solar panels site:wind-sun.com
    Here is a Google search link.
  • bmet
    bmet Solar Expert Posts: 630 ✭✭
    Spinal Tap, anyone?
