Batteries not accumulating power for night
abdoudiaw
Registered Users Posts: 12 ✭
Hi,
I just bought a solar system that includes:
-2 solar panels of 230W each, mounted in parallel
-one charge controller 30 Amps with WellSee Solar software. I have not been able to verify that the charge controller is an MPPT type.
-2 Solite CMF200 200AH mounted in parallel (could not find what type)
-one freezer 12/24volts, 72W, connected to the ‘Load’ of the controller
-one inverter 12v/24v input, 220V output, 1500W, connected directly to one of the batteries. I often leave it OFF.
Every item is brand new.
In daytime everything seems to be working fine but when comes night time the batteries last no more than 2 hours, obviously not having accumulated enough battery.
The max reading of ‘charge’ on the controller has been 12ah while the freezer was taking around 8ah (‘load’ reading), the difference (12ah – 8 ah = 4 ah) supposedly being accumulated into the batteries.
I’m thinking of mounting the 2 batteries in series to have 24volts (and maybe also the panels). Is that a good idea ?
For testing I have only a voltmeter and batteries always read ‘very good’
One panel has the protective glass broken: does this severely affect electric performance? I have left the thousand glass pieces but maybe, while waiting to have the glass replace I should remove these pieces and expose the cells to direct sun.
Thanks for your help.
Re: Batteries not accumulating power for night
From the Solite web site: "Solite is a highly reliable automotive battery that satisfies the car lovers all over the world under any circumstance."
Strike one: Appear to be automotive batteries, not deep cycle type.
Strike two: One panel has smashed glass. Probably greatly reduced output.
Strike three: If your freezer uses an average of 72 watts, 24/7, that's over 1700 watt hours, yet even if both of your panels were operating at 100% efficiency, and there were no losses anywhere in the system (an impossibility), assuming 4 hours full sun each day, you'd only get about 1800 watt hours.
So not counting the drag of running the big inverter, and considering normal inefficiencies and the fact that one panel is damaged, it appears to me that you're not producing anywhere near the power you need, and your batteries are thus being rapidly killed and will soon be garbage.
This greatly saddens me "abdoudiaw", and I wish I had better news for you. Likewise I wish you had asked questions on this form before you decided on sizing your system and what to purchased.
Now lets see what others have to suggest, where do you go from here. -
Pretty simple, do some more reading on this site, as I am short of time I can't write more, but since all calculations follow from the loads, your have in some oredr, too big a loads, too small battery, too small PV to charge that battery etc.
The output from the broken panel will likely be about ZERO and you will not be able to repair it!
Start from scratch with your loads, and work to through to the battery sized required for those loads, and then the PV required to charge those batteries.
Good luck and welcome to the forum,
Tony -
Re: Batteries not accumulating power for nightHi,
Most of these type of panels need a MPPT type charge controller to use "all of their avaiable power"... PWM controllers can be horribly inefficient when Vmp>>Vbatt-charging.-one charge controller 30 Amps with WellSee Solar software. I have not been able to verify that the charge controller is an MPPT type.-2 Solite CMF200 200AH mounted in parallel (could not find what type)-one freezer 12/24volts, 72W, connected to the ‘Load’ of the controller- 72 watts * 0.50 duty cycle * 24 hours = 864 Watt*Hour per day
- 864 WH per day / 12 volt battery bank = 72 AH per day
-one inverter 12v/24v input, 220V output, 1500W, connected directly to one of the batteries. I often leave it OFF.In daytime everything seems to be working fine but when comes night time the batteries last no more than 2 hours, obviously not having accumulated enough battery.
And the broken solar panel, if working now at 1/2 power, will quickly fail. There is nothing you can do that will "save" the panel.The max reading of ‘charge’ on the controller has been 12ah while the freezer was taking around 8ah (‘load’ reading), the difference (12ah – 8 ah = 4 ah) supposedly being accumulated into the batteries.- 12 Amps from controller * 14.5 volts charging = 174 Watts
- 2x230 watts * 0.77 system derating * 1/14.5 volts = 24.4 amps typical maximum current charging discharged battery bank
You may have to choose another charge controller (that supports 24 volts). And if you cannot make the Vmp-Array ~ 35 VDC (i.e., Vmp-Array is >> 35 volts), then you will need a "real" MPPT charge controller (~$300-$600+ USD).For testing I have only a voltmeter and batteries always read ‘very good’- Battery Voltage when charging
- Battery voltage next morning (and if running load or not)
- Battery Resting Voltage (gives estimated state of battery charge)
- 12.7 volts ~ 100% state of charge (no charge/load for several hours--resting voltage)
- 11.6 volts ~ 20% state of charge, battery nearly dead
- 14.5 volts ~ battery charging maximum voltage (battery getting nearly fully charged, charging current will slowly drop over several powers to 2 amps or less, then full charged).
Deep Cycle Battery FAQ
www.batteryfaq.orgOne panel has the protective glass broken: does this severely affect electric performance? I have left the thousand glass pieces but maybe, while waiting to have the glass replace I should remove these pieces and expose the cells to direct sun.
Thanks for these answers.
Here is some addidional info about the products:
Panels: SEM 220 / 215 (I do not have the specs yet but I will check again)
Panels from:
S.E.Project, Padua - Venice, San Pietro in Gù , Italy, EU
www.se-project.it (website not working).
marketing@se-project.it
Controller: LightWave LW-2430 (24V , 30A) with WellSee Solar software/firmware
Is this an MPPT or PWM ?
Inverter: AirStar PIC1500A DC 12V to AC 220V (tried googling but found no website)
Batteries: Yes, it is a 400 AH * 12 volt battery bank (two 12v in parralel)
I'll try to get more readings at different times with and without loads.
I'm in Senegal, West Africa. -
The website redirects over to this one...
And perhaps these are the specifications for your panels (PDF download).
Vmp=29.23 V
Imp=7.53 A
Voc=36.35 V
Isc=8.00 A
Vmp=29 volts is too high of voltage (~17.6 volts required) to efficiently charge a 12 volt battery bank with a PWM controller... And too low (~35 volts required) for charging a 24 volt battery bank with PWM.
Regarding at least this one model of WellSee controller--That one was not MPPT (sorry, forgot to put link in earlier post--also fixed):
Wellsee (60 amp?) MPPT
Thanks ,
Here is the link for the controller:
http://www.wellsee.cc/ProContent_Editor.aspx?action=21
Yes for the panels: from the datasheet you sent my panels look exactly like this one.
Abdou. -
That model is a PWM controller, not MPPT.
So, the efficiency with a Vmp=29.23 volatt panel on PWM controller charging a 12 volt battery bank is:- 17.6 volt recommended /29.23 volt = 0.60 or 60% vs standard "12 volt" panel
- 231 Forum & Website
