Keep snow off solar panels!
Re: Keep snow off solar panels!All I can remember for sure is that a few years ago I saw a charge controller that claimed it could backfeed the panels to melt ice and snow.
Could that controller have been the Classic ?? It's been quite a while (years?) that I/We've talked about this. The only thing I have found on the net, and I've looked hard over the years now, is something about a Sharp (the company) inverter that supposedly did this. I can't find a lot on this though. I would really be interested to know what you have found if you ever remember or find it again.
I do think the most logical place for something like this is something like a communications site that has solar but is running their generators anyway because the array is covered with snow.
OK, Back to work...
boB -
Re: Keep snow off solar panels!DWH, the automation portion you described may have been the downfall of the design. I can imagine a lot of cold cloudy days where a device like that would be tricked into thawing air. I see the need for this to be a manually activated task. Sensors fail.
Good news is the Classic will allow this task to be performed from near anywhere in the world with web access.
I dunno, it seems to me that if you have to activate it manually every time, it would be better to just go out there with a plastic scraper instead. I think some kind of snow sensor is a good idea.
But I agree that you'd have to choose your sensor carefully to ensure that you don't burn energy needlessly. I think the best way to implement the feature would be on a three-position software setting (off/auto/on) so that people can override the sensor to melt undetected snow/ice, or keep it off if the sensor fails or they prefer to clear snow manually. -
I like the idea of a web-cam that is looking at the array to tell if things are working or if anything even needs to be done about it.
Then it could even be done remotely.
boB -
Re: Keep snow off solar panels!I like the idea of a web-cam that is looking at the array to tell if things are working or if anything even needs to be done about it.
boB
But you risk this happening: ( set phasers to disintegrate )
Re: Keep snow off solar panels!I dunno, it seems to me that if you have to activate it manually every time, it would be better to just go out there with a plastic scraper instead. I think some kind of snow sensor is a good idea.
That got really old this winter. Unusually high snowfall amounts and frequency kept me shoveling the roof (and the panels) far too often here. Ladders are no fun while slick and the height and pitch are pretty daunting. I'd have dumped some power to not have to do this.
Wish I could ground mount but far too much shading. -
Re: Keep snow off solar panels!Could that controller have been the Classic ??
IIRC, it was on some online store - i.e., I could have bought it if I'd wanted to. So unless you've been selling them on the side for a couple years and not telling anyone...
I want to say it was part of a kit, but I'm not sure. After napping on it, now I have a glimmer of some memory that maybe it knew when daylight was supposed occur because you could program in the location and time.The only thing I have found on the net, and I've looked hard over the years now, is something about a Sharp (the company) inverter that supposedly did this. I can't find a lot on this though. I would really be interested to know what you have found if you ever remember or find it again.
Yea, I've searched pretty hard for that thing a few different times and no joy.
One problem of course is that Google has fostered an environment where there are 100 pages which serve no purpose other than to display Google Ads for every page with actual information - which has diluted the results from the Google search engine to the point where perhaps half of what you get is trash pages. x10 if your search has the word "solar" in it. Time for a new search engine to come along. If you ask me, these dorks have shot themselves in the foot. -
Ice melt socks keep snow off solar panels all season. -
Well, a separate (small) heated irradiance detector, plus knowing the local time could help determine if it would be worthwhile to burn battery power to melt snow. Mabe AGS included in the options, too. It could take quite a lotta power to do the job ... Think it is on the list of possibilities for the Classic CCs.
We have little snow here. VIcOff Grid - Two systems -- 4 SW+ 5548 Inverters, Surrette 4KS25 1280 AH X2@48V, 11.1 KW STC PV, 4X MidNite Classic 150 w/ WBjrs, Beta KID on S-530s, MX-60s, MN Bkrs/Boxes. 25 KVA Polyphase Kubota diesel, Honda Eu6500isa, Eu3000is-es, Eu2000, Eu1000 gensets. Thanks Wind-Sun for this great Forum. -
For those who use ice melt to keep the snow off the solar panels, does the salt cause any problems for the panels? Are there any parts that can rust from the brackish water? The panels that I'm using now to learn about solar power are on the ground, so I can brush them off. I'm trying to get them to power a shurflo 8000 pump to pump water or to use for a sprinkler system. -
Panel frames are aluminium. Add sodium-chloride solution and you get aluminium oxide, or corroded panel frames.
Not a process I'd recommend. Feel free to disagree. -
I agree that salt is bad for aluminum, but I don't think aluminum oxide is the issue. I think that all bare aluminum is already oxidized. Aluminum oxideCariboocoot wrote: »Panel frames are aluminium. Add sodium-chloride solution and you get aluminium oxide, or corroded panel frames.
sticks to the underlying aluminum (unlike iron oxide which flakes off the underlying iron) and seals it from further oxidation. If I recall correctly, salt breaks down the aluminum oxide coating on aluminum and that leads to corrosion.
Yes, but then again no.
The problem is the same with both iron and aluminium (and any other metal that oxidizes): if the initial layer of oxidation is left untouched the process does not continue. Trouble is, what caused the oxidation in the first place usually erodes the surface layer and exposes fresh metal to assault. Areas where the roads are salted and sanded in Winter know this, as the resulting spray not only oxidizes the cars but "sand blasts" the oxidized layer off. The result is that "lace curtain effect" known so well in those parts. Here in BC we have a saying "Never buy a boat from the coast". This is because it has probably been used in the ocean, and people never rinse the salt water off (or flush the cooling systems)!
I can even show you a whole gallery of photos of oxidation at its artistic best! In Rust We Trust: http://in-rust-we-trust.deviantart.com/
salt or other chemicals will put a film on the glass that will inhibit solar collection and thus cause lowered output. i don't recommend anything that could inhibit power production. -
Nothing beats mounting snow-belt panels in such a way that allows them to be tilted to the vertical for Winter. Snow does not collect on them and best of all, you get extra power output from having both direct sunlight hit the panels, as well as reflected sunlight from the snow covered ground that more than makes up for not having the panels tilted for best possible collection from direct sun only light. No salt, no electric heat, no bonfires to melt the snow. No long handled scrapers to pull the snow down on your heads. So simple, so productive, so satisfying. -
Re: Keep snow off solar panels!I have gone out 2 times with a rubber hammer to knock 2-4" of ice off the panels. Any type of brushing would have failed on my setup. Any heater setup, would/could use more power then the panels would make that day/days. Hammer,broom,scrapper and sun for me.
Note, I have the glassless Unisolar panels, so NO ONE should try the hammer trick on theirs. The neighbors think I am nuts for doing the above action.
I' in the same boat with my neighbors, they dont ever know what I'll do next....seven families live here on the "hill"....they all think I'm nut's, but they like me...I think12 panels 6 series 2 parallel 2100 watts, 1 XW60-150 CC, 16 trojan 6V batteries 8 series 2 parallel 450 Ah, 1 XW 6848 pro, 1 5500 watt champion inverter generator( I know...I need a 12Kw )
- 230 Forum & Website
