Generator auto start and system control panel
I have a Xantrex TR1524 and Honeywell 7500EL generator. I would like to add auto start and a system control panel. Anyone have a suggestion on what would work best?
The generator has electric start but no automatic choke. Any suggestions on how to automate the choke would be helpful too.
I would make do with a battery level monitor and a remote start switch but would prefer auto start.
Jim
Jim
Re: Generator auto start and system control panel
If you convert to propane, does it need choke ?Powerfab top of pole PV mount | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
Here is a several year old thread:
Automatic Generator Starting
At that time, I could not find very much on converting an electric start genset to full auto start... It seemed like it was better to buy a genset already setup for it.
Easier to buy the genset with auto-start already included. But if you have an idea of how the electrical system of the generator works, then you can buy the control unit and add it yourself. I did this with my diesel gen and used one of the basic units from http://www.deepseaplc.com/, cost about 50 GBP and is fully programmable using their PC software. They have models available to accomodate every type of gen setup, so I'm sure finding one to control a choke won't be a problem.
EDIT: Assuming of course that you have an electronically controlled choke! (or can build one)
A not very detailed blog post of my conversion here: http://www.casanogaldelasbrujas.com/blog/2009/05/25/new-control-unit-for-volvox-generator/
- 621 Discussion Forums/Café
