Electroendosmosis 310.10
NEC 2011 section 310.10 Informational Note sites that electroendosmosis may occur in dc wiring between conductor and thermoplastic wire insulation (thwn-2) which is used from array jbox to inverter. Does anyone know whether it's wise to switch to a different conductor insulation type, like USE-2 or PVwire?
-Phil
-Phil
Re: Electroendosmosis 310.10
Here's an older thread on the subject you might want to read through:
http://forum.solar-electric.com/showthread.php?t=7184&highlight=electroendosmosis -
Hi Phil,
Please see this thread, it may help:
Good Luck, VicOff Grid - Two systems -- 4 SW+ 5548 Inverters, Surrette 4KS25 1280 AH X2@48V, 11.1 KW STC PV, 4X MidNite Classic 150 w/ WBjrs, Beta KID on S-530s, MX-60s, MN Bkrs/Boxes. 25 KVA Polyphase Kubota diesel, Honda Eu6500isa, Eu3000is-es, Eu2000, Eu1000 gensets. Thanks Wind-Sun for this great Forum.
- 228 Forum & Website
- 654 Solar Water Pumping
- 619 Discussion Forums/Café
