Is Solar Dangerous on Metal Roofs?
kadesmith
Registered Users Posts: 9 ✭
I just got to thinking about this, is it dangerous to install solar panels on a metal roof? Electricty and metal just don't seem to go well together.
Re: Is Solar Dangerous on Metal Roofs?
Just in the rainPowerfab top of pole PV mount | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
It's not a problem.
Usually only the panels are on the roof (except in the case of micro inverter installs). They are a self-limiting current source. Wires are insulated, run in conduit, panels fused properly, mounts grounded. Thus if any short occurs a fuse will pop, and that's about the end of it.
The exception to this would be poorly constructed "homemade" panels that use something flammable (like plywood) for backing. Unfortunately we still see this from time to time. -
All external (touchable by end user) metal should be connected by copper cable together and to earth ground (building ground/water pipe/etc. depending on your local code).
If there are any shorts--the metal will not become electrified and any excess current should blow a circuit breaker/fuses (if used/required).
Re: Is Solar Dangerous on Metal Roofs?Just in the rain
Sounds like as long as it's done professional or atleast with professional parts then it's not a bad thing. -
Re: Is Solar Dangerous on Metal Roofs?Brings a whole new meaning to singing in the rain.
In fact it may be less risky than asphalt shingles because metal is not flammable. It is possible to get an arc going that could ignite shingles which would only ground out on metal.
It's all about the installation. -
it's not the roof that makes electricity dangerous. no matter the roof involved, one has to be a respecter of electricity. -
I love steel roofs and install them at every chance given a choice. My problem with PV and steel roofs is having to climb up on them for some reason! I can climb a 12/12 pitch asphalt roof without a problem, but a 4/12 with a drop of dew on your boots and you are on the ground! I did not install a steel roof on our new place strictly for that reason, since I have to get up and clean the chimney a couple of times a winter, and sweep the panels of snow once in a while.
Tony -
Re: Is Solar Dangerous on Metal Roofs?I can climb a 12/12 pitch asphalt roof without a problem
You're a better man than me! (or is it "I"?) -
I thought Tony was an old goat, not a mountain goat:p
Ralph -
I don't suggest much of what I do! I framed houses for a very long time, so scampering around carrying plywood up and down roof decks is sort of second nature. A 12/12 with toe boards works alright, but you really should have proper fall protection! (It all sort of explains my knee and ankle problems!)
T
- 228 Forum & Website
- 654 Solar Water Pumping
- 619 Discussion Forums/Café
