Backfeed fault
Radioman
Registered Users Posts: 7 ✭
I have a Xantrex RS3000 inverter/charger. I am getting a AC backfeed fault : Service immediately message. What could be causing this. I believe I have it connected properly. It only happens once in a while. Thanks for any help.
Re: Backfeed fault
Do you have any power sources/AC generators that can output power to the AC output of the Inverter?
What mode is the inverter in when this happens (shore power/charging battery bank; no shore power, running AC power from battery bank; etc.)?
Re: Backfeed faultDo you have any power sources/AC generators that can output power to the AC output of the Inverter?
I have it hooked to a generator. It usually does this when it switches from gen to invert. -
Re: Backfeed fault
I assume the generator is hooked to the AC input of the inverter/charger.
Do you turn of the power then shutdown the genset--or do you turn off the genset (slows down/surges) and let the inverter time the switch over?
(I am wondering if you have an AC motor with some momentum actually driving power back to the genset if the generator engine is turned off while still supplying power--letting the AC motor backfeed the genset a little bit)
Just guessing here.
There also have been problems with failing transfer switches/welded relay contacts that have faulted inverters before. In the Xantrex XW product line there is even an error message for that problem.
Have you talked with Xantrex about the problem yet?
- 226 Forum & Website
- 617 Discussion Forums/Café
