holmes twin fan
billd6373
Registered Users Posts: 5 ✭
What watt panel would I need to use solar for summertime run of this fan I was looking at 40 watt
Re: holmes twin fan
Do you want to only run the fan when the sun is shining? Or do you want to run it in the evening/night.
If you want to run it at night, with a battery bank, then we need to know how many hours a night you want to run the fan and (roughly) where the installation will be (hours of sunlight).
For example, say 10 hours a night for the fan at 40 watts. And it will be 6+ months of the year with 4+ hours of sunlight (assume 52% system efficiency with a AC inverter to run the fan):- 10 hours * 40 watts * 1/0.52 system eff * 1/4 hours of sun = 192 watts of solar panels minimum
- 40 watts * 10 hours * 1/0.85 inverter eff * 1/12 volt battery * 1 day of no sun * 1/0.50 max discharge = 78 AH @ 12 volt battery bank for 1 day of storage
- 40 watts * 1/0.85 inverter eff * 1/12 volt battery * 3 day of no sun * 1/0.50 max discharge =235 AH @ 12 volt battery bank for 3 days of storage
Re: holmes twin fan
Walmart's page lists the fan at 61W
looks like they have misprinted the amps though... 47A??? .47A maybe
Re: holmes twin fan
If this helps, just put a holmes twin fan on a kill-a-watt. It read (both motors running) on HI ---> .47 amps/ 54.3 watts....MED --> .36 amps/ 40.6 watts....LOW --> .32 amps/ 34.2 watts.
cant find the model # but it is the 9" twin, 6 blade, reversible, with manual thermostat. -
Re: holmes twin fan
thanks thats a lot of info but just want to run fan during summer heat wave probably will get battery not to waste ,but still dont know if 40 watt will do the trick -
Re: holmes twin fan
forget buying a battery and inverter and solar PV for a 60w fan, the fan will run for pennys a day, and you have a $100 battery, $300 PV and $50 charge controller and $40 mod square wave inverter , all that cash spent, will buy more electric from the grid, than the fan can use, it will die of old age before you can feed it $500 worth of grid power.
But if your power is intermittent, the fan running off a battery is priceless.Powerfab top of pole PV mount | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
Re: holmes twin fan
Im looking at a 40 watt panel just to run the fan cost 100 why should i pay if the sun will provide -
Re: holmes twin fanIm looking at a 40 watt panel just to run the fan cost 100 why should i pay if the sun will provide
The panel produces DC, and your fan needs AC. Also, panels seldom produce "nameplate" output, and your fan needs about 60W to run. (see the measurement someone made)
Only way to get AC from DC is with an inverter. Or you may want to consider a couple of 12VDC computer case fans.
MikePowerfab top of pole PV mount | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
Re: holmes twin fan
There are also low voltage DC ceiling fans
Tony/Icarus has one in his place.
Re: holmes twin fan
Build6373, another route that you can take, is to use 2 radiator fans from an automobile, build window box, air filter, wire fans in series, use dash board dimmer switch, on/off switch from radio shack, fuse, with fans wired in series, they will pull very few amps. And they will be quiet, and push a heck of lot of air. that is what I did, and only used the AC of a total of 3 days last summer. (Just went to check the AMP on my set up, and it pulls 3.3 amps total on high). but mount the dimmer in front of one of the fans to keep it cool......
this way you can keep the set up simple, with out any conversion loss by using inverters. But the size panel will be your choice. You might not wont to do it this way, sense you got (or thinking to get) the holmes twin fan. well I just threw this out their any ways, just to give you an alternitive idea. -
Re: holmes twin fan
Remember, a 40 watt panel (harbor freight or Northern tool) panels are not very good products. Any Pv will only produce ~80% name plate rating under nearly ideal conditions of full sun and low temps, so your 40 watt panel, best case will only produce ~ 30 watts on average, and that for ~ 4 hours a day.
Add in inverter loses, especially a cheap MSW inverter, wiring loses, and the net/net is likely to be closer to 20 watts out of the inverter! There are 12 vdc paddle fans out there, as well as a you can get for free or nearly free 12 vdc computer fans that will move a lot of air, drawing as little as ~ 5 watts, with no need for an inverter. You could wire them directly to a Pv panel with no controller or battery. The worst that will happen is you might burn them out due to low voltage, but at free, what's the risk.
Quite frankly, define what it is that you are really trying to accomplish, and then design a proper system to do that. Bottom line, like Mike suggests, you are probably not going to save money. As an interesting start to a hobby it may be a fine place to start.
Tony -
Re: holmes twin fan
the panel I saw on youtube was from Harbor and it showed a small fan working well It only drew a little from the inverter -
Re: holmes twin fanthe panel I saw on youtube was from Harbor and it showed a small fan working well It only drew a little from the inverter
What inverter ? Many small fans can run directly from the PV panel. I've NEVER seen a
"small panel * inverter * appliance"
work without a battery somewhere to deal with surges or clouds.Powerfab top of pole PV mount | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
Re: holmes twin fan
Thanks for alternate view does this work with a panel and what wattage would it be. The fan I have fits perfectly can It be adjusted -
Re: holmes twin fan
to use the holmes twin fan, you will need a complete solar set up that will convert D.C. to A.C. For a D.C. fan to run at night time, you will need a battery base solar set up. But just to run during the day time, a panel will work if matched properly. So.........
1) to run a A.C. fan you will need ---> panel, charger controller, battery, inverter.
2)to run a D.C. fan (day and night operation) you will need --->panel, charge controller, battery.
3)to run a D.C. fan (day time only) you will need panel.
and dont forget to add in the cost of proper wiring and fuses. and also on a battery based system, you have to compensate for cloudy rainy days with little to no sun.
so any way you go, it will be very expensive just to run a fan. But all the parts to do any of the steps 1,2 or 3 need to properly matched to work correctly, so it comes to play on your "load" and how and how long that it will be in use? -
Re: holmes twin fan
One alternative might be to use computer case fans. Some will do 100CFM or better. I am using two Antec three speed in our Teardrop trailer. My experience with Holmes is lots of noise and very little air movement because of a very shallow blade pitch and poor design. -
Re: holmes twin fanShadowcatcher wrote: »One alternative might be to use computer case fans. Some will do 100CFM or better. I am using two Antec three speed in our Teardrop trailer. My experience with Holmes is lots of noise and very little air movement because of a very shallow blade pitch and poor design.
See post #11 below,,,
tony
- 194 Solar Information links & sources, event announcements
- 612 Discussion Forums/Café
- 305 In the Weeds--Member's Choice
