A Bug in Blemished Panels
Macaw
Solar Expert Posts: 36 ✭
Here is a new one for me -- I have found a very bright and FLAT bug inside the glass of my ~blemished~ Evergreen panel. The panel seems to work just fine but the bug didn't make it. Zooom in and take a look. The open circuit voltage is fine. I have not checked the short circuit current yet.
Re: A Bug in Blemished Panels
i guess that's one panel that they couldn't get the bug(s) out of.:p -
I have to say that even after many years in this business, this is the first time I have seen something like that. -
The bug will block a small amount of light from hitting a small percentage of the surface area of the cell and an extremely small percentage of the overall surface area of all the photovoltaic cells that make up the panel so I would guess that you might lose a little bit of current but it won't be very much--something in the ma--amps/1000--range. The bug would had have to have been big enough to completely block light from the whole cell to affect output much. -
I would watch for corrosion at that point...
Question is, did it get in post production, and if so how? I would make sure I sealed any possible opening. Perhaps he hatched in the panel. (I am convinced that house flies breed while they are dead!)
Tony -
Re: A Bug in Blemished Panels.....(I am convinced that house flies breed while they are dead!)
They actually don't, but any eggs will hatch.......Powerfab top of pole PV mount | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
Re: A Bug in Blemished PanelsThey actually don't, but any eggs will hatch.......
You gotta do better than that to convince me!
T -
Re: A Bug in Blemished PanelsYou gotta do better than that to convince me!
T
gee, i wonder what kind of drug they'd be taking to keep them going after death.:cool: -
Re: A Bug in Blemished Panelsgee, i wonder what kind of drug they'd be taking to keep them going after death.:cool:
Spanish Fly? 8)
It's the inverse of "Tribbles" Tribbles were born pregnant!
Flies bread while they are dead! That's my story and I'm stickin' to it Capt. Kirk! -
Re: A Bug in Blemished PanelsSpanish Fly? 8)
good one.:D:D
that made me laugh in the wake of some personal bad news. thank you for that.
- 621 Discussion Forums/Café
