Mecasolar Tracker...
iced1124
Registered Users Posts: 5 ✭
Two Trackers being shipped on Tuesday... 15K each, 64 REC235PE's and two SB7000us inverters. I will have the first Single Phase Trackers in the USA...Wish me luck!
Regards,
Iced
Regards,
Iced
Re: Mecasolar Tracker...
Did you do the math on the trackers beforehand? It seems that for $30 000 at a price of $2.3/W you could have bought 13kW more panels on static mounts.
As it stands you have 15kW, so the trackers would have to give you about 85% more output than static mounts to make economic sense. -
looks a lot like what you will see on this page and in their streaming banner ...
http://www.borunchina.com/en/xx.php
their site is quite slow this morning so you will need patience to get the pics to show
check out the SLEW Drive too
cheers
Re: Mecasolar Tracker...westbranch wrote: »looks a lot like what you will see on this page and in their streaming banner ...
I just got a UNSAFE for WORK block when I tried to go there.Powerfab top of pole PV mount | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
Stephen,
Yes..... we did the math...net net, win win....cost of labor AND racking for a static mount..
No way. -
A few more days...all the glass will be installed........if the snow holds out. -
mike here is one of the pics from their site
84 KWH today!!! and it's not tracking yet.
- 228 Forum & Website
- 654 Solar Water Pumping
- 619 Discussion Forums/Café
