fish pond pump -inverter sizing
rama
Solar Expert Posts: 36 ✭
hi all,
quick question - for a 1hp rating fish pond air pump, how big of an inverter will I need? Say I am unable to get the actual rating from the manufacturer, is there a rule of thumb to follow?
I plan to use modified sine wave inverter and my research so far tells me a 1 hp fish pond air pump will require about 1500~2000w of continuous operating power, so 2K or 2.5KW inverter should be chosen?
Does this sound about right?
thanks
thanks
Re: fish pond pump -inverter sizing
It also depends on the surge current too... It is not unusual to plan for a 5x surge current or around a 10kW surge rated inverter (perhaps 5kW continuous rated).
That would probably require a minimum of 500-600 AH battery bank (at 48 volts) to manage the surge current from the motor starting.
If you can figure out how to soft start the guy--it may be a big help (VFD--Variable Frequency Drive)... However, if you are looking at an MSW inverter--you will have to work with the VFD supplier to ensure the one you are looking at will be guaranteed/reliable on an MSW inverter.
The other question is how many hours per day are you planning on running that pump... If 24x7--that will require a lot of solar panels.
If you are only planning on an hour or so per day--then would a smaller pump run longer would possibly address several problems.
Why not go for a DC pump? The host has them as well as others. -
Re: fish pond pump -inverter sizingShadowcatcher wrote: »Why not go for a DC pump? The host has them as well as others.
He (orig poster) is looking for an air pump, 1hp size.Powerfab top of pole PV mount | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
Ah now I understand. What I see around here (Upper Mid West) in ponds are the windmill driven air pumps and fountain water pump type setups.
- 234 Forum & Website
