Worth adding cooling fan for inverter?
spurlocktools
spurlocktools Registered Users Posts: 11 ✭✭
I've had a grid tied system for 6 years using two outside mounted SMA inverters. We have hot summers here (Sacramento Valley) and I have the inverters shaded. However it just occurred to me that possibly a small cooling fan might increase inverter lifespan as well as efficiency on really hot days. I can mount the fan to blow across the cooling fins on top of the inverters. Keep in mind that I already have a small 12v computer CPU fan as well as a small 12v PV panel from an automatic gate opener charger. So it's a no cost addition that would make me feel better, but does anyone have any idea if there would be tangible benefits?
    Re: Worth adding cooling fan for inverter?
    I had a desk fan on a timer, aimed at my inverter, in the garage, and it took 20F off the operating temps, and boosted efficency a % or 2.
    BB. Super Moderators, Administrators Posts: 33,702 admin
    The general engineering design rule of thumb is for every 10C (18F) decrease in temperature, there is a 2x increase in life...
    Obviously, solar equipment only spends 5-8 hours a day at elevated temperatures--so the savings are real--but not huge.
  • spurlocktools
    Great, I'll do it then.
    Thanks for the feedback.
