Solar Leasing in South Florida
tonystewart
tonystewart Solar Expert Posts: 54 ✭✭
Good day
Well my letter had no reply and my phone calls are unreturned so it appears SureTemp Manufacturing is no longer an option. Please see thread for details.
http://forum.solar-electric.com/showthread.php?t=9146
Are there any companies in the US who lease systems to South Floridians?
Looking to reduce my fpl 50% and at 65 kwh day average I feel it needs to be at or near 8 kw grid tie. Alot of lead in was already completed (site survey).
Thank you for your time
T
  • Solar Guppy
    Re: Solar Leasing in South Florida
    Do the insulation and then see what you need ....
    Looking at PVWatts for Miami FL, 8kW system, rest defaults:
    "Station Identification"
    "City:","Miami"
    "State:","Florida"
    "Lat (deg N):", 25.80
    "Long (deg W):", 80.27
    "Elev (m): ", 2
    "PV System Specifications"
    "DC Rating:"," 8.0 kW"
    "DC to AC Derate Factor:"," 0.770"
    "AC Rating:"," 6.2 kW"
    "Array Type: Fixed Tilt"
    "Array Tilt:"," 25.8"
    "Array Azimuth:","180.0"
    "Energy Specifications"
    "Cost of Electricity:"," 9.0 cents/kWh"
    "Results"
    1, 4.61, 811, 72.99
    2, 5.42, 866, 77.94
    3, 5.69, 1009, 90.81
    4, 6.20, 1048, 94.32
    5, 5.63, 959, 86.31
    6, 5.25, 856, 77.04
    7, 5.51, 935, 84.15
    8, 5.54, 943, 84.87
    9, 5.17, 841, 75.69
    10, 5.06, 867, 78.03
    11, 4.55, 774, 69.66
    12, 4.54, 806, 72.54
    "Year", 5.26, 10714, 964.26
    If you get a quote at $5 a Watt installed and 30% federal tax credit--$5*0.7=$3.5/watt installed price. Assume 20 year spread of costs and you have to replace 1 10kW inverter for $5,000--your $$/kWH pricing:
    • (8,000W*$3.50/W + $5,000 maintenance) / (20yr * 10,714 kWHperyr) = $0.154 per kWH
    And, from the other thread, it looks like your current power costs are around $0.13 per kWH...
    The above does not include any loans or other fees/taxes.
    And does Florida charge property taxes on your array (some states do)?
    If your area does not have true net metering, then you may only get paid ~$0.06 per kWH or so (wholesale power rates).
    So--at this point, you are around the break even point for the cost of off-grid power, And an important factor is going to be how your billing details works out with your local utility (wholesale vs retail payments for your "extra power").
    I don't know what is going to happen in your area--But in California we have true net metering (one meter, and a retail credit for excess power generated, perhaps a new program with $0.06 per kWH at the end of the year for any excess power generated).
    But, all of the rebates/net metering/subsidized smaller user costs and other social power programs comes at a cost--We have peak power rates (above roughly 1,000 kWH per month) of $0.40 to $0.58 per kWH (flat rate vs seasonal time of use).
    So--you can look at one possible future and decide if/when solar GT will make sense to you.
    Also, you can look at "extreme" conservation at what you can save at $0.15 per kWH for solar vs even $0.40+ per kWH for power.
    I understand that your have a large home and are way under the power usage of your neighbors... But I keep coming back to looking at the costs and avoid costs of solar and conservation.
    If the returns are not possible with conservation--then GT solar will be your next best investment to address future power increases.
    Solar Leasing throws more confusion at the issue--But putting everything in a spread sheet and looking at how long you are going to remain in your current home (looking 15-20 years in advance--kids gone, moving to smaller home, following jobs, etc.)... It is a difficult decision.
  • tonystewart
    Already in the appointment book for next year Insulstar Plus for the attic ceiling. Doing it after the PV install to seal holes. Used up all my tax credits ($1500)with the new A/C's this year. Hope the goverment extends the program. Solar PV & Water are 30% until 2014 so I want to get in on it now.
    Any recommendations for leasing?
  • tonystewart
    Thanks BB
    I have site survey for my location, orientation & no shading.
    Palm Beach County does not charge property taxes for soalr improvements.
    So who in South Florida Finances? I called a bunch of them and they are not at this time.
    FPL pays half back once per year
    We expect another 20 years in this home. I realize the kids thing that is why I am hoping to get to 50 kwh. Someday.
    If the lease works we are willing..IF
  • AntronX
    AntronX Solar Expert Posts: 462 ✭✭
    Did you look into solar water heating?
  • tonystewart
    Currently we have
    1-4' x 10' Chromagen attached to an 80 gallon GE 12 year warranty water heater
    for the house 141 degrees is the average temp at 5pm
    1-4' x 8' Chromagen attached to the 50 Gallon GE 12 year warranty water heater
    for the master bath 144 degrees is the average at 5 pm
    Both units use DC Laing Pumps & 20 watt solar panels,
    All copper tubing is heavily insulated
    Both Water Heaters have Timer Clocks in case it rains for a week straight but are turned off. Thermostats are set to 110 degrees F
    All 3 showers have water saving shower heads.
    New (1 week old) Kitchenaid Dishwasher is very energy efficient & quiet (41db)
  • System2
    System2 Posts: 6,290 admin
    I have a 4.2 KW PV system, solar domestic hot water, and solar pool heating. You can monitor my system at http://bbbrown.mysolarlog.com/ and read about our installation at http://www.bbbrown.com/ . We live in Palm Beach County also. If you have any questions about our system you can PM me here.
    Bob
